Old 12-07-2006, 10:14 PM
monkey71188 monkey71188 is offline
Unhappy i think its a trans. problem but im not shure
i have a 94 jimmy 4x4 and it has just started to have some problems its got about 175 k miles on it and the problem is that every time i start it up and put it into drive it dosnt go anywhere just the engin is reving but after about 2 sec. it will kick in it dose that untill it is warmed up. so if anybody has any ideas pleas help me.
Old 12-08-2006, 12:19 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: i think its a trans. problem but im not shure
Have you checked the trans fluid level and condition? Should be full to one pint over on the TH700/4L60E, and a nice deep clear red to clear orangish red color, no murkiness, brown/black, metal or strong odor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-08-2006, 12:41 AM
goongrinch goongrinch is offline
torque convertor possibly, check fluid level while engine is running.
Old 12-08-2006, 05:04 AM
muddog321 muddog321 is offline
AF -Advisor
Change the filter and fluid as the first step - probably never done! Should be done every 50k max. Under $100 at any trans shop or DIY for $10 filter and 4-5 qts Dexron fluid - plus a fun mess. Look at the pan there is a flat shallow pan and then a deeper one with a step in it - most 4wds have the step and 2wds the flat I believe. Valoline max has a new fluid that helps clean and reseal thats seems to help the older trans after a filter change.
Old 12-08-2006, 08:51 PM
i changed the fluid and filter about a month ago
Old 12-08-2006, 09:01 PM
silicon212's Avatar
Confoundingly Lucid
Once again, what is the level and condition of the fluid? One month ago isn't today - things do happen.
Old 12-09-2006, 06:00 AM
DelCoch's Avatar
DelCoch DelCoch is offline
The symptoms you described are identical to a transmission that is 3-4 quarts low on transmission fluid, and also identical to a transmission that needs the bands adjusted or one having a bad pump. So, if it’s not low on fluid you will need to visit a transmission shop.
Old 12-09-2006, 03:01 PM
how much would it cost for a new pump and to adjust the bands?
Old 12-09-2006, 03:40 PM
Blue Bowtie's Avatar
Registered Offender
The only band "adjustment" on a TH700-R4/4L60E is to replace it. There is no band acnchor adjustment screw any more, since the bands really don't wear unless there is a serious problem. A new pump probably isn't necessary at only 175K unless something else has failed and scattered metal poweder all through the trans oil.
Before getting all hot and excited about replacing hardware, perform a line pressure check and see what's really happening. You can do that without even draining the oil pan.
Old 12-09-2006, 03:57 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Pay attention.
Go for a 10 miles drive and get the engine and tranny warmed up.
Park and leave the engine running.
With you foot on the brake, go through all the gears from park to 1 and back up to park and hold it in each step for 20 seconds on the way down and on the way up.
Do not touch the gas when cycling through the gears.
Then check the fluid level.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-11-2006, 10:24 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I agree with Blue Bowtie. For sure a line pressure test will give you a very good indication of whats going on in the transmission. This test, along with a trans capable, bi-directional scanner is what professionals use to diagnose trans problems, so looking at line pressure is a very good start.
