Old 12-07-2006, 05:42 PM
92-silverado7.4's Avatar
92-silverado7.4 92-silverado7.4 is offline
ToeKnee
Help changing a capacitor!
I need to change a capacitor in a fosgate amp. The problem is that it has a bunch of numbers like 22000uf, 35v, and 105 degrees celcius. I bought one with 2200uf, 35v, but the degrees celsius are higher, does that make a difference?
Old 12-08-2006, 07:53 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Help changing a capacitor!
I hope that one of uf is a typo ..... if the voltage is the same, the 22000 will be a LOT larger than a 2200. The 22000uf is the capacitance, the 35V is the maximum voltage rating, the 105 C is the max temp range ... as long as it is at least as high as the one it came with, you will be fine.
Old 12-08-2006, 01:11 PM
ToeKnee
Sorry I messed up, what I was trying to say is that both of the caps are 2200uf and 35v, but the one that blew up had 105 degrees celsius, and the one I bought has a higher number of degrees celsius....do the degrees celsius really make a difference?
Old 12-08-2006, 02:45 PM
bjboertje's Avatar
bjboertje bjboertje is offline
it just means the higher one can handle more heat. you are fine if it is the same uf with equal or higher voltage and temp ratings.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-08-2006, 04:16 PM
ToeKnee
yeah...that's what I tought, but I wasn't sure, thanx for the help guys!!!!!
