Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-07-2006, 11:09 AM
BigDaddyRoc BigDaddyRoc is offline
Need Help 1994 Suburban
need help two days ago fuel pump died so replaced it, coil wire was bad so replaced plugs wires cap rotor and coil..truck ran fine for two days then just died again got it home replaced the ignition module and still wont crank ..any one got any ideas fuel pump comes on when i turn on the key but not getting fire at the plugs now and now have even replaced the oil pressure sending unit..still nothing
Old 12-07-2006, 04:21 PM
maxwedge maxwedge is offline
A990 racer
Re: Need Help 1994 Suburban
Welcome to AF. If the fuses are all good and you have 12v to the coil I'd be checking the pick up in the distr., also make sure the bad coil wire did not fry the coil tower.
Old 12-07-2006, 06:59 PM
the Pick up coil in the distributer is testing good, so I dont believe thats the problem, as far as the tower I changed all the wires, plugs, cap, rotor, so the old coil wire was taken off when new stuff went on
Old 12-07-2006, 07:25 PM
A990 racer
No spark, focus on the dist and coil and circuits to it. Check this link, see if it helps. http://autozone.com/servlet/UiBroker...3d80085d3a.jsp
Old 12-21-2006, 09:59 AM
back2life's Avatar
back2life back2life is offline
Well Did U Guys Figure Out What The Problem Was? If So Let The Rest Of Us Know Please!
Old 12-22-2006, 04:19 PM
twistedtech twistedtech is offline
I agree,please let us know.I just stopped in to check out a couple of threads I was in and there are not any result posts.Noticing alot more of that lately.Please people by all means take the time to pick our brains,but take the time to let us know what happened.TY.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 12-22-2006, 04:27 PM
A990 racer
Thumbs up Re: Need Help 1994 Suburban
Agreed on that. Lots of info given out on all these forums and no feedback!
