Old 12-07-2006, 09:15 AM
LittleREDM&Mcrx LittleREDM&Mcrx is offline
car bogs out when i floor it
okay i have a 89crx with a d16z6 head on d16a6 block mini me swap. My problem is that when I floor it the car bogs out but if i release the accerator about an inch the car starts to pick up again. Could anyone help me? ...thanks
Old 12-07-2006, 12:36 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: car bogs out when i floor it
Check your fuel Filter.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-07-2006, 10:29 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
no check engine lights?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-08-2006, 12:58 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
`check your timing or slightly advance it and see how it is.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 12-08-2006, 03:29 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
bogs without check engine lights are rare.
but,
that would also depend on what the definition of bog is.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-08-2006, 10:15 AM
there are no check engine lights but upon closer inspection I noticed that my purge control solenoid wasnt wired up to the ecu. Could this be my problem??
Old 12-09-2006, 12:44 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
TPS maybe
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 12-09-2006, 12:48 PM
Turns out p28 ecu doesnt use a purge valve solenoid. I did notice my vtec solenoid was leaking some oil though. I noticed the harness was oily all the way from where it plugs in down the line. It was the only thing that was oily in the bay. This is pissin me off.
Old 12-09-2006, 04:25 PM
Tony's Avatar
TLD Member #1
Have you checked the fuel filter? Don't assume its someting complicated without checking the simple things first.
Tony
Old 12-09-2006, 06:58 PM
bambam89lx's Avatar
AF - Advisor
check the voltages for the MAP and TPS sensors, and verify that they are withing spec. The fact that you don't have a check engine light is wierd though. Because of that, it may be timing related. Verify your ignition timing with a timing light. Also, set the motor to TDC and verify your cam timing.
