Old 12-06-2006, 11:23 PM
agcneo's Avatar
agcneo agcneo is offline
oops, blew up my blazer
ok i have had alot of problems with my blazer, tranny sensors, engine problems, sinkin it in the pond. and when i thought she had gone through it all, tonight was the last straw. drivin down the road i heard an enormously loud explosion, folowed by a large flame shooting out and up from under my blazer. i coasted to my buddys house, bout 500 ft away, looked under and what did i see?? well my piston rod was laying ontop of my skid plate. i looked up, and there was no sign of the piston. there were shards of metal everywhere, and i could fit a fist and a half in the hole on the engine.. i had just done an oil change no more than 2 weeks ago, checked my levels yesterday, and they were fine. now there was a slight misfire on Cyl. 6. and thats the one i was holding in my hand earlier tonight. thought i had gotten it fixed, but i guess not. not sure if shes worth tryin to fix, put a new motor in, or get a jeep grand cherokee laredo. anyone got any input on what i should do,and/or what caused this catastrophy?
you may have a faster car.....but i can still drive over yours
Old 12-07-2006, 12:24 AM
TheBrettster TheBrettster is offline
AF Premium User
Re: oops, blew up my blazer
Screw Jeeps, put a new motor in.
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 12-07-2006, 07:49 AM
agcneo's Avatar
ok so what is involved in putting a new motor in, and i have been hearing that a 305 bolts in?! if that is the case, does anyone know what it takes to do that??
Old 12-07-2006, 03:34 PM
someguy000001 someguy000001 is offline
Sorry for your loss, but that's kinda awesome. Did you take any pictures? If so, please post 'em.
Old 12-07-2006, 05:13 PM
laxman21's Avatar
laxman21 laxman21 is offline
yeah! sorry, that sucks as i have been through it
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 12-07-2006, 05:43 PM
thadrawr's Avatar
thadrawr thadrawr is offline
Send a message via AIM to thadrawr
Dont go for a jeep you will regret that. Every jeep I have ever seen or ridden in is complete garbage.
1999 GMC Sierra 1500
Old 12-07-2006, 08:09 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
[quote=agcneo]ok so what is involved in putting a new motor in, and i have been hearing that a 305 bolts in?! if that is the case, does anyone know what it takes to do that??[/QUOTE
Stick with the the 4.3, a much easier swapout. And avoid sinking it in the pond next time, or if you do keep her running as long as you can to dry her out evenly. you may have kept the top end above water and kept her running while not noticing you had already caused a fatal condition in the lower end. water sucks off heat fast.
Old 12-07-2006, 09:34 PM
agcneo's Avatar
ya the water was bout 35 degress, and it shut off as soon as it sank, it sank nose first. submerged up to the top of the steering wheel. but i have disconected all the wires hoses and stuff like that, loosend the tranny bolts, but i cant figure out how to get ot the motor mount. any one got any expereince on that?! it would be greatly appreciated, i am planin on gettin her back on the road by saturday, does that sound unresonable? found a new motor, $650 with 80,000 on it, or $700 for 70,0000 on it. i was lookin forward to that 305, but oh well. so yes, if anyone has any tips, advice, pointers, anything to help me get this motor out i would appreciate it sooo much, thanks! and does a 95 2dr tranny fit a 97 4dr ??
Old 12-07-2006, 10:32 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
same trannys are used (4l60e) reguardless of cab configuration. getting at the motor mounts are a pain. you can't really get at them fromt the top so you have to get them from the bottom. i was workin on a friends 95 and we had pretty good access to the mounts (although the whole front axle was out of the truck )
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 12-08-2006, 12:10 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
No. They are different. The '95 is a unique year for the 4l60e tranny in these trucks.
Old 12-08-2006, 01:04 AM
agcneo's Avatar
ok... so i need to find another tranny .. oh well. so anyone know how to get this beast out? its a pain in the @$& so far...... i kinda have the urge to take a sawsall to it.
Old 12-09-2006, 09:27 AM
agcneo's Avatar
well i did just that, took a sawsall to the radiator support, that worked well and smoothly, it was pretty rusted anyways. heres a tip for anyone removing these engines, take the radiator support off!!( unbolt it though) u get straight on with the motor mounts. saves you from either having to go from underneath or work your way around the damn steering shaft. anyone know what i have to do to get the tranny off? or is it just unbolt it from the motor and im in the clear?
Old 12-14-2006, 07:43 PM
agcneo's Avatar
anyone know how to get the torque converter off?
Old 12-15-2006, 01:19 AM
Jari's Avatar
Jari Jari is offline
If you have same oil pan as in my car (aluminium which covers tranny). Remove right side wheel, remove starter and cover plate and you can access torque conv bolts from there..
Old 12-15-2006, 09:53 AM
agcneo's Avatar
GENIOUS!!! i would never have thought about that! thanks for ur help
