Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-06-2006, 10:59 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
195/70 R15 instead of 195/60 R15?
I need some snow tires to hold me over this winter:
195/60 R15 are on the rims now
guy is selling 195/70 R15
Mountable?
Also, if I mount them on the front wheels (just two) this ok?
FWD 1992 Eagle summit with 15" OZ rimsopcorn:
http://www.georides.com
Sub Compacts, Electrics, Biodiesel, hydrogen
Old 12-07-2006, 05:19 AM
CapriRacer CapriRacer is offline
Re: 195/70 R15 instead of 195/60 R15?
You didn't tell us what vehicle this is going on, so we can't tell you if the tire is too big for the fenderwells.
Plus we need to know how wide the rim is.
Obviously the best situation is all 4 tires being the same.
Next best is the grippiest tires on the rear, so you are less likely to spinout.
But if only 2 is what you have, then you have to do what you have to do.
Old 12-07-2006, 08:34 PM
RightWingZionist's Avatar
RightWingZionist RightWingZionist is offline
Exclamation Re: 195/70 R15 instead of 195/60 R15?
Dude! He did say what car and doing what he has to do aint good advice if he don't know what he has to do.
Here use this:
http://www.miata.net/garage/tirecalc.html
Diameter will be 1.5" taller, it will be 1.5" closer to the top of the under fender on top of your tire. Consider this changes when you turn the wheel all the way.
On a small car like that I don't believe it's a good idea, front's being taller than rears? No way man, NO GOOD IMO.
