Old 12-06-2006, 10:22 AM
Btd36 Btd36 is offline
Question overdirve light sometimes flahses
hi all,
Justb bought a 1999 Windstar LX its been fine but yesterday the O/D light flashes sometimes. It will not stop flashing untill I turn off the ignition.
Any Ideas would be appreciated.
Thank You in advance,
Brian Whited
Old 12-06-2006, 11:33 AM
Freakzilla69 Freakzilla69 is offline
Re: overdirve light sometimes flahses
That's a warning... that you are about to get your transmission rebuilt.
Seriously though, I had the same thing happen to my '98. After a while it stopped going into 3rd gear. Eventually 1st started slipping and then later fluid started pouring out.
From what I've read that's an indication that your transmission has gone into "limp mode" and you need to get it serviced quickly.
I thought it might be an electronic problem when it first started, from some other posts I've read. You can try replacing the Transmission Control Module, Speed Sensors (there are two, vehicle and shaft), Neutral Safety Switch and there are up and down Shift Solenoids. Did I miss any???
None of that worked for me. I had it rebuilt for $1,800.
Good luck.
Old 12-06-2006, 09:25 PM
wiswind wiswind is offline
The flashing O/D light is indicating that there has been a problem detected with your transmission.
I would recommend having a shop read the transaxle codes....these are different from the OBDII codes......
The Flashing O/D light is like the Check Engine light is for the engine and engine control systems.
A fault code is stored...which will be an indication of what you should do to correct the problem.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-08-2006, 10:23 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
I had a flashing OD on my 95. It turned out that the speedsensor that I put in when I had the heads off just because it was easy to get at failed! I put in a new speed sensor and it shifts like new with 210,000+ on the whole van.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
