Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-06-2006, 08:58 AM
Xeiros's Avatar
Xeiros Xeiros is offline
Send a message via AIM to Xeiros
Stutter when acclerating hard.
Hi guys.
I'm trying to figure out a problem I've got with my car right now. If I have to accelerate hard for any reason, my car will stutter for a few seconds, and start going. It's usually as the turbo starts to spool. I'm going to change the fuel filter and spark plugs anyways, but besides those, what do you think it could be? Could it be something wrong with the turbo itself?
I've got a 95 Eclipse GS-T.
Thanks.
Old 12-06-2006, 11:20 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Stutter when acclerating hard.
Do a boost leak test. If you don't know how or what that is, do a search you will find instructions easily. Also make sure you gap your plugs to .028".
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-06-2006, 12:18 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
If it were a boost leak his problem would worsen as it built more pressure, not get better... I have my money on a spark issue or fuel issue. Change your plugs, wires, fuel filter, and give the air filter a check just for good measure as well.
Do you have anything done to the car or is it pretty much stock?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-06-2006, 01:16 PM
Xeiros's Avatar
As far as I know, it's completely stock. I just purchased it within the last month, and I believe the previous owner was the only owner, and from the sounds of it, they weren't much of a tuner.
Old 12-06-2006, 02:27 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Does it run fine at idle? Do u have a check engine light? The only time when my car stuttered like that is when i forgot to plug back in the MAF sensor after doing some work. Good idea to do all the new filters plugs and wires after buying it just so u start out fresh.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 12-06-2006, 03:04 PM
Xeiros's Avatar
Yeah, I don't put it to chance and run on old parts that are cheap to replace. I like to be safe.
I don't have a check engine light on, and it idles fine as far as I'm concerned. I did notice it would idle around 600-800 RPMS which I thought might be a bit low, but I'm used to my GM's that idle around 900-1000. It doesn't struggle to stay on or anything.
Old 12-06-2006, 08:22 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
What brand and number of plugs did you put in?
95 Talon TSI AWD
97 Eclipse GST
Old 12-07-2006, 12:25 AM
True, but I would bet he would find one or two anyway.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-08-2006, 09:38 AM
Xeiros's Avatar
It might be a boost leak after all. I checked the plugs and wires, and they look good. I'm still going to replace the plugs, but the wires look almost brand new, so they were likely replaced very recently. I haven't replaced the fuel filter yet, but thats my next step.
I messed with it again yesterday, and first and second gear didnt have the problem, but going into third, when boost hit, it stuttered good, and it kept doing it till I let off, though not as bad as when boost intially starts hitting. It did it in fourth and fifth as well.
I just ran my tank dry, put some techron fuel system cleaner in, and put some 93 octane fuel in there, as I suspect the dealship likely put some crap fuel in there to begin with.
I'm really hoping this isn't a major mechanical problem.
Old 12-08-2006, 10:08 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I cant imagine stuttering on acceleration to be major man, I bet after you find the problem you will be done with it.
I bet the dealership put som fuckin 87 in there and it was running all shitty cause it was pulling timing out the ass to keep it from eating itself. Either that, or you have a decent sized boost leak or maybe a bad PCV valve? Do yourself a boost leak test and get a new PCV valve, fuel filter, plugs, and looks like you got some 93 in there so I bet once you get done with all that you will be good.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-08-2006, 11:45 AM
Doesn't matter how new they look, they can still be bad. Example A: I'm on probably my 6th set of wires for the Firebird in the last 2 years. Why?: Because the heat from everything melts down the insulation thin enough in certain sections and then it actually arcs through the insulation to something. I also have a pair of brand new magnacor wires that I got from my friend that I was gonna put on my Talon. My brother went to use them and they were no good at all for some reason. So I still stand with my original solution here. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 12-08-2006, 12:12 PM
Change the plugs, I bet that's your problem. I worked on a 95 gst that stuttered instantly when boost hit because he put in some platinum plugs and it ate them up right away. Go with some stock NGK's and maybe new wires and I bet your problem goes away.
95 Talon TSI AWD
97 Eclipse GST
Old 12-08-2006, 01:22 PM
Xeiros's Avatar
I don't doubt you at all black crow. I'm just starting to think there might be some boost leaks that aren't helping the situation any. And now that I see someone recommended I stay away from platinums, thats exactly what I'm NOT going to replace them with now, lol.
Old 12-08-2006, 05:06 PM
Turbo car + platinum plugs = problems
NGK BPR7ES I think is the exact model of plug you want to throw in the beast. Gap them to .028" and you will eliminate that as a possible problem source.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-09-2006, 12:07 AM
If problems still persist after that, go for the wires then...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
