Engine Problem?
Hey guys! I have a 97 Ford Contour 2.5 V6 engine that has been overheating since the other day...The engine is getting really hot and there is no heat coming out of the vents, it just blows out cold air...I thought it was a thermostat and took it to a repair shop that replaced it and everything...still have the same problem...the mechanic told me that the radiator isn't getting hot and the engine isn't getting any coolant in it...now I'm out $160 with the same problem... The coolant is fine, there aren't any leaks of any kind, could it be the water pump? It has been really cold here and I spent a while trying to get my car out of the parking lot here...my engine was working a lot with a lot of tire spinning...could I have blown something? If anyone could help me out that would be freaking awesome! Thanks! |
Re: Engine Problem?
Waterpump is broke. Its a common problem and is covered in the FAQs on www.contour.org. I suggest checking out the forums over there. Heck of a lot better than this one. If you have any more problems, check the FAQ or check the troubleshooting forum on www.contour.org. If you can think of a question, its already been asked and answered.
"Car is overheating, but thermostat is fine! Heater blows cold air." http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=9 And of course, the how-to on to replace it is also on CEG. http://www.contour.org/mods/mods.php...o&displayid=14
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
Re: Engine Problem?
Wow...thanks for the reply!
Re: Engine Problem?
Re: Engine Problem?
Find a new mechanic too. Any mechanic with half a brain should have been able to fix this the first time around.
