Go Back   Automotive Forums Car Chat > Cadillac > Fleetwood
Old 12-05-2006, 07:14 PM
stonedraiders1213 stonedraiders1213 is offline
engine problem
I dont know what happen. the car was low on gas and I started it to go get gas. It run for at least 5 minutes and then it turned off. I think that my fuel filter went out but dont know for sure cause I can still hear the motor going on it. I have replaced the fuel filter and still the car starts but turns off. I have filled the tank and dont know what else it can be. can somebody help please.
Old 12-05-2006, 08:21 PM
maxwedge maxwedge is offline
A990 racer
Question Re: engine problem
Welcome to AF, I know you are anxious about the problem, but stop and think here what year is this car, what engine?
Old 12-06-2006, 01:39 PM
Re: engine problem
the car is a 1993 with 93k on it. engine is v8 I dont know what size. please if you can help. thanks
Old 12-06-2006, 02:32 PM
DFBonnett DFBonnett is offline
Re: engine problem
The next thing to do is try to pull up any codes. On my '93 Eldo I sit in the driver's seat, turn the key to ON, then simultaneously hold down OFF and WARMER on the climate control. Watch the dash to see what if any codes come up then post back here with them.
You can also spray some starting fluid into the intake. If it starts then dies you have a fuel problem most likely due to a clogged fuel filter or a bad fuel pump. At that point you'll need to put a pressure tester on the line to cheack it out.
If nothing happens when you spray the starting fluid, pull a wire off of a spark plug and holt just away from a good engine ground while a helper cranks it over. You should hear and see a spark. If you don't it is an ignition problem.
Have you checked all the fuses?
Old 12-06-2006, 05:38 PM
Re: engine problem
ok I did that and no codes came out. I changed out the fuel filter so I know its not that. It might be the fuel pump. It starts and runs slugges and then turns off. maybe not enough fuel going into the engine. Do they make maintance book for the fleetwood?
Old 12-06-2006, 05:49 PM
Re: engine problem
Both Barnes & Noble and Amazon have Chilton and/or Haynes manuals. They are also available locally at auto parts stores and some of the big box stores like Walmart and KMart.
It sure sounds like a fuel issue. You need to check the fuel pressure and check the fuse for the injectors.
Old 12-06-2006, 10:09 PM
Lightbulb Re: engine problem
I have check at auto zone and kragen. I have never seen a book for the 93-96 fleetwood broughams. I will have to check the fuel injectors tomorrow morning. How do I check the fuel pressure???
Old 12-07-2006, 06:46 AM
Re: engine problem
In front of me at this moment I have a Chilton manual which covers 1990-1993 Deville, Fleetwood, Eldorado, and Seville. I bought it in Kmart about 7 or 8 years ago, before I bought a set of factory manuals on Ebay.
To test the fuel pressure you need a pressure tester for fuel injection. It connects to a schrader valve on the fuel rail. You need about 40+ lbs, IIRC.
The test procedure is covered in the manual.
Old 12-07-2006, 09:31 AM
Re: engine problem
ok Im going to go look again. I think I saw that book but it said for the front wheel drive. Mine a rear wheel drive. I hope thats the book. I will go to auto zone to get the pressure tester. about how much do they run???
Old 12-07-2006, 10:48 AM
Re: engine problem
P/N - 21030
Manual Title - Cadillac Rear Wheel Drive all gasoline models '70 thru '93
Haynes manuals has the above. The Chilton manual FI diagnostics should be the same however, even though it is FWD.
I paid around $20 for my FI pressure gauge at Pep Boys, IIRC.
Old 01-02-2007, 06:05 PM
Re: engine problem
thanks for all the help. I finally got it fixed. it was the fuel pump. thanks again.
