Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-05-2006, 04:49 PM
derf derf is offline
Need a "hot" switched wire?????
Installing an accessory that requires a hot switched wire. One that goes on with the ignition. I just can't find one. I tried one of those fuse extensions on my daytime driving lights and the lights did not work any more. Had to take it off. Any help would be approecated.
Old 12-05-2006, 05:50 PM
2000CAYukon 2000CAYukon is offline
Re: Need a "hot" switched wire?????
If you already have a fuse extension (like http://www.gizmos-gadgets.com/index....c2b71a903617d8) then hook into the accessory fuse.
//2000CAYukon
Old 12-06-2006, 07:56 PM
WEF WEF is offline
Mini fuse extender worked for me. Maybe you bought a bad one?
Old 12-09-2006, 04:28 PM
Bevl Hvn's Avatar
Bevl Hvn Bevl Hvn is offline
along the same lines, is there a place in the firewall to get wires from the inside to the engine compartment easy? I want to add a big rig air horn, and additional driving lights. I don;t want to drill a hole if I don;t have to. Ideas?
Old 12-09-2006, 05:25 PM
There is a fuse box under the hood. You should be able to use a fuse extender, or run a fused line off the power coming from the fuse box.
//2000CAYukon
Old 12-11-2006, 08:17 PM
Bevl Hvn's Avatar
Cool. But I will still need to run wires into the cab for a switch..... Ideas on where/how?
Old 12-12-2006, 01:10 AM
There should be a gromet with wire going thru already in the firewall near the drivers feet. You can easily run a wire for a switch thru this gromet.
//2000CAYukon
