Old 12-05-2006, 02:56 PM
etuke etuke is offline
1993 1500 4x4
today we had a nice bit of snow and I was out plowing with the truck,everything worked fine except for a single clunk when going from rev to forward,Im thinking I have a bad front universal from the transfer case to the diff.I went home and took off the plow and while backing out of the driveway(just idling back)the truck just stopped as if I had ran into a snow bank.I went forward no problem and then back again and it did the same thing I think the front and back wheels locked and skidded on the snow.I went forward and then back again and had no problem since,there isnt any noise while in 4wd on the road other than the extra drive shaft turning(and maybe a bad joint).I know a bad universal wont lock the wheels so something other than that caused it,also I was back up straight,any ideas??The truck seems to drive fine in 2 or 4 wd.
Old 12-05-2006, 05:19 PM
2000CAYukon 2000CAYukon is offline
Re: 1993 1500 4x4
http://www.drivetrain.com/gillies/Tcasesaver.html would be my guess.
//2000CAYukon
Old 12-05-2006, 07:09 PM
Re: 1993 1500 4x4
that looks like a fairly easy fix,but what are the symptoms of the broken snap ring?What does the snap ring do?It said something about a pump not working when it broke but I wasnt aware that the transfercase had a pump.
Old 12-05-2006, 07:44 PM
Re: 1993 1500 4x4
Usually low speed grinding sound along with a pop sound.
http://www.automotiveforums.com/vbul...ght=Tcasesaver
It can also cause the transfer case to lock up.
//2000CAYukon
Old 12-05-2006, 08:58 PM
Re: 1993 1500 4x4
thanks for the info but mine dosent make any noise in 2WD,only happened in 4WD and it wasnt the noise it just locked in reverse for a sec but when I get the chance I will check it just to make sure.I need to heat the driveshaft bolts to get the shaft out,I tried this summer to replace the t-case seal but couldnt move the bolts.
Old 12-06-2006, 10:16 AM
bigj-dog's Avatar
bigj-dog bigj-dog is offline
Re: 1993 1500 4x4
Might be way off, but mine had a problem with the pinion nut on the rear end loosening up, causing the pinion to push into the ring while backing up, maybe your front diff. has the same problem?
Old 12-06-2006, 03:35 PM
Re: 1993 1500 4x4
Anythings possible,will take a look this weekend,if I find the problem I'll post back.
