Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-05-2006, 01:05 PM
cntrchfrk cntrchfrk is offline
Exclamation Help Please Horn!
i was cut off yesterday by someone.. (welcome to NY)
my horn went from a loud strong sound to a whimpy 1 tone high pitch noise.
what can i do about this?
what happened?
where is the horn?
thanks again you guys never let me down
-chris
Old 12-05-2006, 01:46 PM
Dr98 Dr98 is offline
Re: Help Please Horn!
Year of truck-
Replace horn located behind drivers side headlight.
Dean
Old 12-05-2006, 05:48 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
One of your horns may be failing. You probably have two horns, a high pitch and low pitch.
Do you have a multimeter or test light so you can test for voltage to the horn once you find it?
-Rod
Old 12-06-2006, 04:26 PM
1996 ford explorer...any yes i can check voltage but havnt yet
Old 12-08-2006, 07:44 PM
shorod's Avatar
SHO No Mo
As Dr98 mentioned, the two horns are mounted in the left front corner above the fender apron. Per the service manual, the steps to replace the horns is as follows:
1. Raise and support the hood.
2. Remove the horn bracket bolt.
3. Remove the fender apron bolts.
4. Position the fender apron aside.
5. Remove the horn.
-Disconnect the electrical connector.
-Remove the horn.
-Rod
Old 12-10-2006, 07:03 AM
97explorersport 97explorersport is offline
Post Re: Help Please Horn!
5. Remove the horn.
-Remove the horn.
-Rod
before you remove the horn bolt you need to either remove or partially remove the fender apron to get at the horn bolt.
