Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-05-2006, 12:41 PM
tuesd97 tuesd97 is offline
Angry 97 ram 1500 360 4x4
I'm having transmissions troubles can u help. It just all the sudden stopped shifting. Was running 65mph slowed down and went to go again and tranny would not shift. I never had any signs of slippage or grinding. What should I do.
Old 12-06-2006, 11:33 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 97 ram 1500 360 4x4
It might be just a sensor. Take it to a mechanic for diagnosis is what I would do. Trans problems can't usually be solved by the owner.
My Mopars
Old 12-06-2006, 12:28 PM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Most transmissions have what is commonly called a "limp home" mode. It kicks in whenever the transmission detects a problem. My 96 chev did it and would only go forward in 2nd gear. The dealer repaired it under warranty by replacing the ignition switch. Go figure.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 12-06-2006, 03:31 PM
BleedDodge's Avatar
No way?! That's pretty crazy.
My Mopars
Old 12-07-2006, 02:37 PM
we had sensors checked along with all linkages no problems there. Truck goes into gears easly just will not move when you give it gas. Is there a sight I can get onto that will give a tranny diagram. Thanks for all your help
Old 12-11-2006, 02:33 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Do you feel the truck actually engage when you shift it from N to 1st then disengage when you put it back into N? Put it into 4wd H. Shift into 1st and press the gas to see if the front wheels pull you at should eliminate Transmission. Otherwise it could be your rear end
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 12-16-2006, 04:10 PM
wafrederick wafrederick is offline
Banned
Try changing the thermostat too,the transmission will not shift when the coolant tempature is not right.Had that happen to one and it was a bad thermostat.Here is another thing to check,the bottom transmission line towards the radatior and it is the rubber hose part.It is removable from the line.There is a nylon checkball inside that line and there is one thing to do to that checkball:get rid of it!You can drill it out or take a long #2 phillips screwdriver to tap it out.The problem is that it melts and will plug the line up resulting in a burned up transmission.
