Old 12-05-2006, 11:32 AM
gtp'n gtp'n is offline
dual climate control
Has any one a light got out on there dual climate control. I have out out in the bottom left hand corner and it is driving me nuts. Has anyone had to replace a bulb in it yet? how difficult is it. any directions? searched the forum and came up with nothing.
I have a 2000 GTP
Old 12-05-2006, 01:21 PM
troy1 troy1 is offline
AF -Advisor
Re: dual climate control
Radio shack sells a 12volt T1 bulb that will work but the acuall bulb is a T 1.75
The bulb has to be soldered in and out with a low wattage (30 or less) soldering iron
http://www.servicelighting.com/catal...m?prod=EK40910 these bulbs are for around the temp control nobs not all the buttons.
Take the dash apart remove the unit. You will need a T10 torx socket or screw driver to take the unit apart pull the nobs off and unscrew the nuts with a pair of needle nose pliers and everything else is clipped to together.
Old 12-05-2006, 02:50 PM
Thanks for the info. Sounds like a job that might have to wait until it warms up a little. can not be without heat.
