Old 12-04-2006, 09:41 PM
chevyguy502 chevyguy502 is offline
Send a message via AIM to chevyguy502
overheating 88 K-5. need help asap.
I recently replaced the fuel pump, coil, and gave it a tune up. Problem after problem. Now my blazer is overheating. It was running off the gauge so i pulled over. No leaks, it has fluid, and now it won't start. my only thoughts are either thermosthat or water pump. How can i tell if it is the water pump, and is there anything else it could be? Its a 350 TBI. Its my daily driver, so i need to find out quick. Thanks!
Old 12-04-2006, 10:05 PM
pappyl pappyl is offline
Re: overheating 88 K-5. need help asap.
If it's the pump you should see the coolant leak around it. But you said it was not leaking...
Overheating without a leak -
belt broken
Plugged radiator (rare)
Bad intake or head gasket
Cracked Block
Hope you have a leak...
Running HOT - also bad timing
It won't start???? Do you have fire/ do you have gas?
