Old 12-04-2006, 07:52 PM
n_lopezIII n_lopezIII is offline
Cool 97 Merc Tracer sputters at accelleration
I could use some help. i had pulled some codes 1102 map sensor. I had replaced the map sensor and also the harness to map sensor cause was told they go bad. It ran find for 3 days and then it will die out on accelleration from a stop. i had replaced the complete tune-up w/motorcraft parts. Replaced Ilde Air and TPS sensors And vacuum hose to pcv. But still having same problem. Timing belt has been replaced and I double checked timing marks they are good. So if you have any suggestion, would like to hear them.
Old 12-04-2006, 10:16 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 97 Merc Tracer sputters at accelleration
Check for vacuum leaks. Inspect all vacuum hoses and mating surfaces of the intake manifold.
Old 12-08-2006, 12:26 AM
I have checked and replaced some vacuum hose-still same problem
Old 12-08-2006, 01:08 AM
Are you still getting the code after replacing the sensor?
Old 12-08-2006, 09:58 PM
Yes I'm still getting a code p1101 map sensor and p102 map sensor low circuit
Old 12-08-2006, 10:57 PM
Maybe try a compression check. I still suspect a vacuum leak.. perhaps from the head or manifold.
Old 05-23-2007, 11:00 PM
tracer95 tracer95 is offline
Try replacing your spark plug wires. I had the same problem and checked for vaccum leaks, replaced the plugs, and ignition coils module, finally the wires and the problem went away.
