Old 12-04-2006, 06:10 PM
indieforlife indieforlife is offline
97 grand prix blower motor
Having trouble, please help. I have a 97 Pontiac Grand Prix that had a blower motor burn up. I have replaced it but cannot get it to power up. I had the part tested where I got it, and checked all fuses. It ran one time and then it quit again. I see postings about a resistor. Is this something I need to look into? Please email me at [email protected] if you have any suggestions. Thanks.
Old 12-05-2006, 09:19 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 97 grand prix blower motor
Welcome to AF.
If you have a manual climate control then it sounds like you have a bad blower motor resistor. It is located behind the blower motor. Blower motor must be removed to replace the BMR.
See tech procedure here
Timeslip 08/12/06
AF Community Guidelines
Old 12-05-2006, 09:28 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
AC-Delco part number for the manual A/C resistor is 15-80571 (GM#89019101) just for reference. If you have the Auto/Climate control, it's a blower module, AC-Delco part #15-8756 (GM#52479971).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-07-2006, 09:41 PM
jem270's Avatar
jem270 jem270 is offline
I pulled the blower motor out of mine the other day and the hardest part was disconnecting the electrical connector to the motor. The connector has a button like tab that you have to push to disengage it then you pull the connector apart. It would help if you had three hands.
1997 Grand Prix SE, 3.8 (L36), 4T60-E (auto) M13
2002 Grand AM SE1, 3.4 (LA1), 4T45-E (auto) MN5
2003 Silverado LS, 5.3 (LM7), 4L60-E (auto) M30
1988 Ford Bronco EB 5.0 (AOD) manual BW1356 & hubs
Old 03-06-2012, 05:03 PM
anc33 anc33 is offline
HELP PLEASE ,.,.I have a 97 grand prix gtp, I replaced blower motor and the resistor ,checked all fuses inside and under hood of car,, and still blower doesnt work,, someone please tell me if theres anything else I should check or replace,....
Old 03-06-2012, 05:05 PM
GTP Dad GTP Dad is offline
Pontiac Guy
See response in your other post!
