I have just bought my first 200sx. 96 uk model. The boost is reading just 2psi. The car has had a bleed valve fitted but it appears to be doing nothing. I have checked and there are no leaks from turbo to inlet manifold. Has anyone any ideas? Do you know what the standard boost level should be? Please help!
Re: 2psi boost problem
bleed valve or blow off valve? stock boost is around 7psi...it shouldnt be too hard to tell if its actually boosting 2psi or not. it would be slow as fuck.
![]() S13 Silvia Q's - R.I.P. R32 GTST Type M Sedan - Sold R32 GTST Type M Coupe - Sold S14 Silvia K's - daily R32 GTS4 - BETTER BE READY!!! |
the actuator might be broken... check it!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
if the actuator was broken wouldnt it just not stop boosting. one time my hose came off my actuator so ther was no pressure to open the wastegate.
maybe its a wastegate problem.
93 hatch W/SR20 BLKTOP, FMIC, blitz BOV, tien coilovers, rsr exmag exhaust, downpipe, wallboro fuel pump, custom oil cooler W/ ebay oil filter relocation kit. apexi afc neo next upgrade = z32 brakes all around 210 hp/215 tq to the wheels |
if the actuator arm was broken, then the wastegate flapper would just come open and not build boost. pressure check the system to see for leaks, check wastegate setup.
1988 conquest TSI -Lots of mods, finally finished WOOT!! ![]() Horsepower sells cars, Torque wins races! |
that makes sense. with the arm being broken. shit how often do those break, never thought about that problem before?
^never heard of it breaking^
same here, unless you have some massive engine vibration.. or it being rusty as hell
-Matt NISMO ![]() 1992 240sx SE Fastback 5speed ![]()
ive never seen an arm break either, but it matters what design you have, mine has a nut adjuster so if your did it can come loose and come off (the arm now being split in 2 pieces) or it can be out of adjustment. I would check your actuator and make sure the diagrahm is still good and working.
Maybe your turbo is blown. Maybe your boost gauge is bad.
