Old 12-04-2006, 04:12 PM
zachzchw zachzchw is offline
Send a message via AIM to zachzchw
clean the transfer case?
I had my u joints fixed (again, second time in two years), and asked the guy to check out other things, including all the fluids and so on.
He said my transfer case fluid looked bad, the t case needs to be cleaned and refilled.
My question is, what would make it need to be cleaned out? I drained the old fluid and filled it with new a few months ago. I did use the correct fluid, so Im wondering what would make it need to be changed again already.
Old 12-04-2006, 05:05 PM
muddog321 muddog321 is offline
AF -Advisor
Re: clean the transfer case?
If a Bravada(??) then you really should be using blue AutoTrak syn fluid as the GM bulletin states for your full time case same with the AutoTrac 236 cases. Yours has clutch packs in it. Now if you did use blue and its now dark (red + blue) its possible the tranmission seal is leaking and red flowing back into the transfer so look at the transmission level.
Old 12-04-2006, 07:18 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
i would be very weary of him
changing the fluid is all that would be needed ot be done
if it is THAt dirty then there is something wrong
good point about leakage between the case and the tranny however, that is very possible
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 12-04-2006, 08:00 PM
Sorry, forgot to mention that it is a bravada.
I put the blue fluid in it when I changed it. I know it sounds like he is just out to make a buck, but he said he would do it if I just bought the fluid, so I dont think thats it.
Its a friend of my father in law, who is the manager of autozone, so he would be doing it as a favor to him, more or less.
