Old 12-04-2006, 12:40 PM
stnapycnaf stnapycnaf is offline
Unhappy Mystery Sound
I bought my 91 CRX HF in late august ...
it runs fine ... no problems with the engine or tranny
except this odd mystery sound ... its like a heavy rattling in my engine bay
i thought it could be the heat shield rusting away and rattling so i removed it
and it still makes this ugly sound
its most prominent in 1st gear around 3000 rpm and gets more and more
subtle as I shift up ... but its still noticeable ...
I just dont know what it is and its driving me insane ... help please
91 CRX HF
D16A6 Swap
Old 12-04-2006, 01:31 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Mystery Sound
Does it continue even when it's warm, or does it eventually go away after a few miles? I know in my car, when it's cold, the wrist pins are loose and rattle until it gets warm enough for everything to expand.
Old 12-04-2006, 01:38 PM
Re: Mystery Sound
nah man ... cold or warm ... doesnt matter ... sounds like it could be in the tranny ... but it doesnt kick in until the high 2's or 3000 ...
91 CRX HF
D16A6 Swap
Old 12-04-2006, 01:40 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Mystery Sound
Yikes! that's not normal, unless you are talking about low-silicon forged pistons.
As for the rattle, it's most likely the heat shield on your catalytic converter, or further down the exhaust...those are the more common ones.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-04-2006, 02:47 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Mystery Sound
Do you still have the factory exhaust manifold and "A" pipe? If so it might be the inner wall of the "A" pipe has broken loose and rattling around inside (does it sound like a ball bearing rattling inside a can?). I know this because mine does the same thing. It could also the catalytic matrix inside your convertor has broken loose. GL
Old 12-04-2006, 04:38 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Mystery Sound
Check your cat converter heat sheild. Jack your car up and wiggle it to see of its loose. Heres how to fix it:
http://fourthgenhatch.net/cat.html
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 12-04-2006, 06:45 PM
Re: Mystery Sound
I think i'll record the sound and post a link ... cause i've already removed the heatshields ... all that other stuff I have no idea ... I'm very car dumb right now
it doesnt really sound anything like a spraypaint can or anything ... its hard to explain ...
91 CRX HF
D16A6 Swap
Old 12-04-2006, 08:39 PM
CivicSpoon's Avatar
There is no Spoon
Re: Mystery Sound
My friend (certified mechanic) seems to think it's fine. He says Mitsu Mirages do it right from the factory and that I have nothing to worry about. I'm not really worried about it, as long as I get another 6 months or so out of the engine I'll be fine.
Old 12-04-2006, 11:39 PM
bambam89lx's Avatar
AF - Advisor
Re: Mystery Sound
Do me a favor and go outside; look at the rear of your car. Is there a mitsubishi symbol on it? If so, you MAY be ok. This "mechanic" you are talking to, is nothing short of dumb. People seem to like to throw around the term "certified" like it actually means something. My friend Mike who is "certified" comes to me for his engine builds. Hey, he knows how to change a starter and rotate some tires though.
Seriously though, it's not normal. 6 months is wishful thinking, if it is infact a damaged piston/wristpin.
Old 12-05-2006, 09:31 AM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
Re: Mystery Sound
that sounds like the same problem i have. mine only happens when i accelerate quickly though.
90' Honda Civic Si
2001 Volkswagen Golf 1.8T
Old 12-05-2006, 10:43 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Re: Mystery Sound
yeah i was thinkin the heatshield round the catalytic converter myself..
Old 12-05-2006, 12:00 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: Mystery Sound
i just cut the shield off of the cat when i put in my 2.5 straightpipe. i havent put my test pipe back on mine since i got it worked on but even with the stock cat it sounds beastly. im just glad i dont have e-checks
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 12-05-2006, 12:04 PM
Re: Mystery Sound
e-checks as in CEL? why would ya unless ur running without a o2 sensor?
Old 12-05-2006, 12:25 PM
CivicSpoon's Avatar
There is no Spoon
Re: Mystery Sound
Well it sounds like my friend has a lot more experience than your friend does. He actually builds his own engines (as well as changing starters and rotating tires). And I'm well aware that my car isn't a mitsu, and I was going to mention something about that but I figured no one would go with the same old bs of feeling the need to point it out; because it seemed pretty obvious. I just mentioned it to prove a point that it might not be that bad since other cars do it straight from the factory and run fine for a long time. But whether it's a mitsu, ford, or honda; engine components are relatively the same. They have pistons and connecting rods, and wrist pins. And the fact that the sound goes completely away after the car is fully warmed up to operating condition. But what do I know, I'm no engine building guru...
Old 12-05-2006, 12:30 PM
Re: Mystery Sound
well my friend works at the local grocery store in the produce section and he can change spark plugs!! looks like my friend has more experience then both of ur friends *tongue out* haha!
