Old 12-04-2006, 12:38 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Model Rocket Engines
what size are they? the dimensions of them? I'm building a model rocket car for art class (yes i'm that guy) and I need to know what size the drill hood should be for a block of wood and how do you think I should hold the engine in?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 12-04-2006, 10:33 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Model Rocket Engines
I think thiers many sizes, and the diameter differrs.
The small ones are 18mm OD(thats a tight fit).
Best bet is to pick up the ones you need and measure that way you dont have to drill twice. Just my
1999 Grand Am SS 3.4 OHV
Old 12-04-2006, 11:15 PM
AlbanyCartel's Avatar
AlbanyCartel AlbanyCartel is offline
"Model rocket motors produced by companies like Estes Industries and Quest Aerospace are stamped with a code (such as A10-3T or B6-4) that tells several things about of motor."
"Motors are commercially available in many sizes. The Quest Micro Maxx engines are the smallest at a diameter of 6mm. The company Apogee made 10.5mm micro motors, but those were discontinued in 2001. Estes then comes in with "T" (Tiny) motors that are 13 mm in diameter by 45 mm long, while standard A, B and C motors are 18 mm in diameter by 70 mm long. Larger C, D, and E class black powder motors are also available; they are 24 mm in diameter and either 70 (C and D motors) or 95 mm long (E motors). Some motors, such as F and G single-use motors are 29mm in diameter. High-power motors (usually reloadable) are available in 38mm, 54mm, 75mm, and 98mm diameters."
From left, 13mm A10-0, 18mm C6-7, 24mm D12-5, 24mm E9-4, 29mm G40-10.
Wiki
Old 12-05-2006, 12:24 AM
Dyno247365's Avatar
hmm, What would you use on a rocket car this small?
Note - wheels will be thinner, rocket bay may need to be lengthened.
Old 12-05-2006, 01:14 AM
Dyno247365's Avatar
better edit
Old 12-05-2006, 03:09 PM
ghostrx7's Avatar
ghostrx7 ghostrx7 is offline
Send a message via AIM to ghostrx7 Send a message via Yahoo to ghostrx7
i used to love those things! too bad it took alot of time to get a few launchings.... id say the c should be big enough right? a d blasted a rocket 100's of feet in the air, so something on wheels........
88 10th anniversary rx7 and company h2.
[IMG][/IMG] [IMG]
atkins streetported 3mm seal engine, act clutch, lightweight flywheel, downpipe, straightpipe, greddy power extreme exhaust, hks ssqv blow off valve, short shifter, tein flex suspension, energy bushings, bonez intake, new brakes, rotors, toyo tires, mazdaspeed replica seats
Old 12-05-2006, 06:56 PM
C should be fine for what he's doing.
AlbanyCartel, how much thrust do those engines put out ?
I couldnt find any faqs on aproximate thrust.
Where I live you have to have a license to purchase those larger rocket motors. I was thinking 24 mm was teh biggest at hobey stores. You can order big monsters but you have to be a real rocket junkie. Sucks spending a year building it and 30 sec for things to go wrong(to explode)
Old 12-05-2006, 08:20 PM
Dyno247365's Avatar
How do you think NASA feels?
Old 12-07-2006, 08:31 PM
Dyno247365's Avatar
3D Design Project - Rocket Car
Pics of my progress (5 hours of work today)
The hardest part was sawing the pieces in half, because our teacher said he didn't want us cutting the wood in half (height wise) w/ the bandsaw because we'd cut our fingers off. So I used hand saws.
I left class early with my friend and we picked up some supplies and came back to class. One of these was a 2-1/4 hole cutter drill bit, using the drill press, making the wheels was easy. Besides this girl was making a toy car and the way she made the wheels made me cringe. Work smarter, not harder.
Nice engines huh? guess who sells them, MICHAEL'S CRAFTS STORE. All that's left are the axels, sanding down/shaping, and gluing. Btw see all those fins? lucky scraps from cutting, save everything!!
Old 12-07-2006, 09:39 PM
those are some big rockets for such a small car.
it might just take fly with those babies
Looks Good Though !
Old 12-09-2006, 06:43 PM
Dyno247365's Avatar
1 day from completion, I made some changes.
First, I took the recovery of the rocket engine into account and will drill all the way through the block and remove the aero-wedge there, so it looks like a jet engine. Then I'm buying a piece that will hold the rocket engine in place so it doesn't work like a rocket launcher. In order to do all of this I raised the position of the block up from where it was, so it's even more taller in the back.
The front axles are just about done. Without using any metal, I cut short pieces of the dowel I bought and attached it to another small block (may prove to be bad for aerodynamics, but it adds some weight to the front. The Wheels roll nicely. Pictures when I finish.
Old 12-12-2006, 10:27 PM
Dyno247365's Avatar
I finished on sunday, but I may need to make some changes before I actually race it. The people in my art class especially liked how I talked about building it and how it works. It wasn't really 'art' though compared to crafts. So what?! It took a back seat to some other projects but I'm sure they'd change their minds when they saw it run.
Here's the final pics (before a possible video)
Baby's got a Brand New Bag!!
It was a crazy transformation from the piece of pine wood to this, you know just by looking at it.
I'm going to go to a hobby shop and ask around to see who wants to race it. I need to lower the front right axle because only 3 wheels touch the floor.
Old 03-14-2007, 01:33 AM
GreyGoose006 GreyGoose006 is offline
thats pretty cool
i'd suggest making the rocket aim slightly up, pressing the car its self down.
otherwise, it'll probably just spin about in circles.
edit:
and i just saw the date...
sorry.
Old 03-20-2007, 11:26 PM
Dyno247365's Avatar
Originally Posted by GreyGoose006
thats pretty cool
edit:
sorry.
The good news was that this wasn't engineering class, the bad news was that no one really cared in my art class...some people but not others, and I had by FAR the best project...pfft!!!! I didn't launch it, I actually need to reglue one axle. It's at home with my parents now. Frickin great fun to make.
Old 03-21-2007, 11:14 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
you need to get video of that thing launching, that'd be sweet. in high school my physics teacher had a bunch of model rockets that we'd launch every once in a while, they were sweet. we never got a good measurement on the highest one of them flew but it was over 400m(1,300ft) in the air. that one was a bigass one with i believe an F but it could have been a G. we launched alot and most of them got to about 200-300m but it wasn't uncommon for us to get a bunch around 400m in one day.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
