Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-04-2006, 11:41 AM
Big N Big N is offline
92 s-10 4X4 will not engage
I am new to this sight. I was wondering wier the vacume hose was located at to engage the 4x4 on my 92 s-10 blazer?
Old 12-04-2006, 11:52 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 92 s-10 4X4 will not engage
http://www.automotiveforums.com/vbul...d.php?t=498411
http://www.automotiveforums.com/vbul...d.php?t=498812
Old 01-25-2008, 01:12 PM
lilloon lilloon is offline
first you need to check to see if the tansfer case is engaging. if it is, then under the battery tray theres an actuator for the front diff. when engaged it should be sucked in . and the rubber boot should be free of tears and cracks. i dont know if you have push button or the lever to engage 4x4. also, theres a vacuum switch the top of the t-case. if sends vac to the actuator. it gets its vac form the rear of the intake. hope this helps.
Old 01-25-2008, 05:56 PM
old_master's Avatar
Advisor/Moderator
This thread is over a year old, please check the date before you dig up an old bone. Thanks
Closed Thread
