Old 12-04-2006, 12:36 PM
burijon's Avatar
burijon burijon is offline
2000 Intrigue P0101 P0410
Got my codes read at Autozone and had them reset the codes. As of this writing they are still off. I just replaced the Crankshaft Position Sensor yesterday and the service engine light was off. While driving the car last night for 50+ miles it kicked back on.
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0410 Secondary Air Injection System Malfunction
Other than the obvious MAF sensor I see from other posts that it could also be the catalytic converter.
Any other suggestions are appreciated.
Old 12-04-2006, 04:50 PM
dtownfb dtownfb is offline
Re: 2000 Intrigue P0101 P0410
i've had the Mass Air flow code pop up twice on my Intrigue. having read others with this problem, I knew changing the Mass air sensor is the last resort.
I changed the air filter; cleaned the mass air flow sensor; really cleaned the throttle body as it was sticking. this worked both times. Mine seems to happen when I get severe carbon buildup on the throttle body plate. After doing this, the CEL went off within 5 miles and has not returned.
Not sure about the P0401 code.
Old 12-04-2006, 08:17 PM
maxwedge maxwedge is offline
A990 racer
401 is Auxiliary AIR system, not the cat, could be the hose off the air pump or a bad check valve in the air system.
Old 04-01-2007, 11:07 PM
2002 2002 is offline
mine right now has the same code: 410. i was told at the dealer that there were two valves at the bottom of the air pump that werent holding any suction. price: $250 apiece. mine has a tendency at surging at idle on occasion
2002 olds intrigue gl, 3.5, 87k
Old 04-03-2007, 07:04 AM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
there is a TSB, here's the jist of it..........
Bulletin No.: 04-06-04-037
Date: May 27, 2004
Subject:
Check Engine Light On, DTC P0410 Set, Water in AIR Pump (Replace AIR Pump, Install New Hose and Shield)
Condition
Some owners may comment on the check engine light being illuminated. Upon investigation, the technician may find a DTC P0410 indicating that there is a concern in the secondary air injection system. When removing the air pump, the technician may also note evidence of water intrusion in the secondary air injection pump.
Cause
Water may have collected in the AIR pump and frozen or corroded the pump.
Correction
Replace the Secondary Air Injection Pump and install a new hose, shield and cleaner
2003 Pontiac Grand Prix 3.8 Litre V6
ASE Certified Master Tech
Old 04-10-2007, 01:14 PM
burijon's Avatar
Is this the GM part # that I need for a Secondary Air Injection pump?
12561866
What about the "shield"? Does that have a part number?
Thanks.
Old 04-19-2007, 12:01 PM
GMIredneck GMIredneck is offline
Question Re: 2000 Intrigue P0101 P0410
Another question regarding that secondary pump replacement. Will the problem just happen again or does the replacement prevent that condition from reoccuring? Anyone have experience with this?
