Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 12-04-2006, 09:43 AM
jsoundguy jsoundguy is offline
Thumbs down check engine light/ egr problems
The check engine light is on code reads egr excessive flow. Now i have heard it could be egr valve or dpfe sensor any one have a clue which it should be and if it is the dpfe sensor (and what this is called at the parts store?) anyone know where it is on a 2002 mountaineer 4.0 v6 RWD. Please help
Old 12-10-2006, 07:50 PM
fordman922 fordman922 is offline
Re: check engine light/ egr problems
This happened to my wifes car, 2002 AWD. I ended up changing the sensor and the check engine light disapeared. The sensor is located near the fire wall on the RH side. If you open the hood and stand on the RH side (passanger side) and just behind the valve cover is the sensor. It connects to a couple of tubes and there is a single electrical plug.
I was told that the 4.0L was notorius for the sensor going bad.
Hope this helps.
Old 12-10-2006, 08:02 PM
Thumbs down Re: check engine light/ egr problems
Hope this helps.
Do you know what this sensor is called can you get it at the auto parts store or dealer only and how many miles were on your wifes
Old 12-11-2006, 12:30 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
This sensor typically called the DPFE sensor (Differential Pressure Feedback - EGR).
-Rod
