Old 12-04-2006, 09:08 AM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
problems as usual
ok i got a fun wonderful wiring problem again. my "C" clip on the ecu was tragically broken and i had to put in a new clip. so i put in a new clip that i thought was from the same year civic but the clip will not click into the ecu. also now when i press my brakes i get the door ajar light on the dash but no rear brakelights. also my map senso is not working. ive tested for continuity and for the map and brake lighhts and they are iin the right pin hole. i dont know what to do anymore tried to buy a new interior harness but that turned out to be not for my 1990 dx close but no dice. as usual any help would be great and yes i know this is a stupid problem. thanks
Old 12-08-2006, 01:07 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
Re: problems as usual
Well, only thing I can think of is to get the right clip for your ecu and trace your steps to correct the problem or try a different ecu. You may have shorted out a connection or two, hence creating issues for you. I hope this works.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 12-08-2006, 08:15 PM
yeah its been hard to find a 90 hatch around here. any body out there got a 1990 civic hatch out there that i can get the ecu conections off
Old 12-08-2006, 10:47 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
The plugs are the same for all 88-91 hondas/acuras.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-09-2006, 12:28 AM
EF_LSVtec's Avatar
I was wondering about that cuz if they were the same, then why won't the replacement clip latch on the ecu?
AF Bay Area Crew
Retired SOLD 1/08
Old 12-09-2006, 12:47 PM
well it turns out a pin on the ecu is bent or i should say crumpled. is it possible to repair this or is it trash
Old 12-09-2006, 02:39 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
just repin it.
-tony-
2000 honda s2000
Old 12-09-2006, 08:06 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
im gonna run to the junkyard tomorrow after i get out of work since itll be a little warmer. i gotta get this hatch runnin..cant wait on parts any longer..
want me to look for anything?
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 12-09-2006, 08:15 PM
bambam89lx's Avatar
AF - Advisor
use a set of needle nose and bend it back into shape.
Old 12-11-2006, 11:09 AM
ive tried to bend it back but i cant get in there with out bend all the pins around it.and i doubt i could get the pin to staighten out enough i mean this thing is like a crushed pop can man it bad. how would i go about repining it do i have to replacethe whole clip thing io probly can i got spare ecus laying around that dont work it looks like the whole dam clip is replaceable. well i dont know.thanks
Old 12-11-2006, 04:29 PM
bambam89lx's Avatar
AF - Advisor
Just use a thin screwdriver and unbend it. I can't see how it's so bad that you can't straighten it out just a bit, enough for the plug to get a connection.
Old 12-14-2006, 11:18 AM
the pin is laying in an almost spiral at the back of the clip the floor if you will an i can bearly move it around with a screwdriver its so fucked im thinking if i do end up straitening it out it might break form being bent so much but whatever i will get it taken care of somehow it just always takes a week or two till i come back to it with a diffrent mind set. also its not like its bent to the left or right a little bit this pin is demolished
