Old 12-04-2006, 05:10 AM
GT11 GT11 is offline
Oil coming from bell
95 GMC Jimmy, 4.3 Vortec, auto tranny. Noticed oil dripping on cardbord on the shop floor. Coming out of the little hole on the botton front of the bell housing. Enough to be concerned about. Got an idea its a rear main seal but never did one before on this vehicle. Ideas, thoughts, constructive comments?
Thanks
GT
Old 12-04-2006, 03:16 PM
maxwedge maxwedge is offline
A990 racer
Re: Oil coming from bell
Engine oil or trans fluid? either way rear seal or trans front seal the trans must come out, make sure this is not something running down from the back of the engine.
Old 12-05-2006, 05:02 AM
Engine oil. I kind of wish it was the tranny. Found a Gmc/Chevy tranny guy at work. Guy knows his stuff. Tranny needs a going thru, 156K miles. Once the tranny is pulled, can I get to this rear engine seal? Is it best to put the truck up on 4 stands? Give me a run down on what is needed (steps) to do this job.
Thanks
GT
Old 12-05-2006, 03:21 PM
A990 racer
Rear seal is behind the flywheel. For R and I info go to autozone.com/repairinfo, you will need good equipment here ,this trans and transfer case can be very unwieldy. Think about doing this yourself, may want a real shop environment and equipment, I would..
Old 12-05-2006, 07:12 PM
herkyhawki herkyhawki is offline
Back the truck up!
You don't even know where the leak is yet. It could be the intake manifold or the distributor O-ring. Dist o-ring is cheapest and easiest so start there.
Do you really want to drop tranny and replace main seal, only to have the leak continue fromsomewhere else??
Old 12-05-2006, 08:24 PM
A990 racer
Thumbs up Re: Oil coming from bell
Agreed, what I suggested in my first response.
