Old 12-04-2006, 03:15 AM
c8r9x c8r9x is offline
Send a message via AIM to c8r9x
Help with turboing a crx
what size of an oil return hose should i use and how do i retard my timing does anyone know were i can buy hoses and ends for the oil line thanks for the help
Old 12-04-2006, 11:00 AM
CRXSiR1's Avatar
CRXSiR1 CRXSiR1 is offline
Re: Help with turboing a crx
Try here http://www.full-race.com/catalog/ind...ath=34_180_541 and here http://tunertoys.zoovy.com/category/oillines/
Dan The Fisherman
Old 12-04-2006, 01:35 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Just buy a complete oil line kit. Save the headaches. Also, make sure you get an oil line restrictor. Our honda oil pumps pump at extremely high oil pressures compared to most cars. High oil pressure is the worst thing for a turbo. This is the reason most turbo honda's burn oil, when nothing else is wrong; the high pressures force the oil past the turbo's seals and into the turbo housings. The restrictor will drop the pressure down to 25-30 psi, which is perfect.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-04-2006, 10:46 PM
i already have the oil line feed and i have the drain flange what kind of hose can i use or do i have to buy the return kit thanks
Old 12-05-2006, 12:00 AM
bambam89lx's Avatar
AF - Advisor
You can use a fuel/oil resistant high temp section of hose if you'd like. Make sure it has at LEAST a 1/2 inch ID though. Use high pressure clamps as well. I would've bought a complete kit, but oh well.
Old 12-05-2006, 01:35 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
http://www.honda-tech.com/zerothread?id=119100 -oil return line
http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
http://www.honda-tech.com/zerothread?id=118807 -oil feed line
http://www.honda-tech.com/zerothread?id=119681 -oil feed line
http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
http://www.honda-tech.com/zerothread?id=126335 -oil t question
http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
http://www.honda-tech.com/zerothread?id=134078 -feed diagram
http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
http://www.honda-tech.com/zerothread?id=155510 -oil leaks
http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
http://www.honda-tech.com/zerothread?id=195068 -oil pressu
thank testudo from HT. theres no excuses for not understanding oil lines now is there
screw the timing retard.........get some real engine management.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-05-2006, 02:18 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
if you're in need of an oil line kit, then go to www.stealthmodeperformance.com and get one....
---also, check out the customer spotlight....what a nice car! That guy must be totally cool as hell!! -----
by the way, that's my car if you didnt get the joke
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
