Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-03-2006, 11:14 PM
junkyardboy25 junkyardboy25 is offline
my 95 talon won't turn over and start
someone plz help. i have this 95 eagle talon my uncle gave me as a gift, but there's a catch. it won't start, or shud i say turn over. it has the 3 elements the car needs to start. but now i'm just stuck...
Old 12-03-2006, 11:56 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: my 95 talon won't turn over and start
Please read the rules (link in my sig) and post in the correct subforums.
What 3 elements are you talking about? Turbo or non turbo?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-04-2006, 04:02 PM
It has fuel air and ignition. it's a non-turbo. iv change the spark plugs, also the starter. i also checked to see if i even had sparks kuming from the plugs. but it still won't start. what else do you suggest i do?
Old 12-04-2006, 05:19 PM
Thor06's Avatar
Jizzed In My Pants
So its getting correct fuel pressure at the rail and air is pretty much a given. Its not even turning over? Did you check the battery? Check fuses? So is it making spark or not? Can you smell gas out of the exhaust pipe after cranking it a little?
There are a couple other things essential to engine operation that you should check and thats mechanical timing (check the timing marks on the timing belt) and cylinder compression.
From what you gave me to go on, I am putting my money one either A) you have dead battery, B) the timing belt skipped a bit, C) you have a blown ECU, or D) the fuel pump shit they bed.
