Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-03-2006, 09:44 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
tps
just wanted to know, besides a check engine light, what symptoms would a faulty throttle position sensor cause?
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 12-03-2006, 11:53 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: tps
It may throw off your idle and make the car run rough or randomly surge.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-03-2006, 11:55 PM
Re: tps
it would run rough and surge, even while driving? and could it only be intermittent, one minute/hour/day work fine and the next, run rough and surge, while idling or driving?
eclipsed @ 3am
Old 12-04-2006, 12:35 AM
scizzle scizzle is offline
Re: tps
yeah, thats pretty much it.
Old 12-04-2006, 07:09 PM
Re: tps
It's could, yes.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-04-2006, 07:14 PM
Re: tps
wow all this really helped out a lot. im pretty sure that the tps is failing then. and that would make perfectly good sense, seeing as how thats what the scanner said. on last thing i want to ask about, can you test the tps with a volt meter? if so, how, and what should the results be? thanks for all the advice
eclipsed @ 3am
Old 12-04-2006, 11:51 PM
Re: tps
You could test one with a meter, though probably an ohmmeter. It will most likely be a resistance check. just get a haynes manual from any local autoparts store, online or even meijer or something like that. the book will tell you everything about how to do it and what you need. and its only like ten or fifteen bucks.
Old 12-05-2006, 01:20 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: tps
A present for you my friend.
http://www.plymouthlaser.com/tps.htm
1991 GSX 2.3 Stroker
Old 12-06-2006, 02:05 AM
Re: tps
Excellent research. Thats one to save.
Old 12-06-2006, 04:24 PM
Re: tps
thanks defiancy, for that link. it seems pretty helpful, ill probably check it tonight or tomorrow. one thing i was wondering, is a chilton or haynes manual the same as a "shop manual" ? i only ask because i notice they say "repair manual" and the chiltons manual is pretty broad, "90-99 mitsubishi eclipse rs/gs/gst/gsx". is there a more specific manual that i can buy?
eclipsed @ 3am
Old 12-06-2006, 08:24 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: tps
I have the Chiltons manual and it's awesome, it has breakdown of each of the cars under each "Repair" listing. Either one will work for most of the stuff you need to fix.
95 Talon TSI AWD
97 Eclipse GST
Old 12-09-2006, 11:57 PM
Re: tps
alright hey, this is just an update.
i took the throttle body off today. first thing i saw? one bolt from the tps was missing, it was only held on by the top bolt. i didnt have the multimeter or anything, so i couldnt check that, but i took all the sensors off and completely throttle-body-cleaned the whole thing, and lithium greased the crap out of the throttle plate cable spring thing. one thing about the throttle plate, it feels spongey. it didnt have a very crisp movement like others. it feels ~somewhat~ better than before i put the grease on it. any ideas for that?
eclipsed @ 3am
Old 12-10-2006, 02:02 AM
Re: tps
WD-40 that bitch until it squeels like a little greased up piggy.
Soak it in degreaser if you have to. It's probably just really clogged. Then WD-40 it for better movement.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 12-10-2006, 01:24 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Re: tps
I think i too have a screwd up tps. one day it runs nice, the next day it runs crapy, then the next few days it run nice,then the next runs crapy.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 12-10-2006, 09:16 PM
Re: tps
i read somewhere before about a "wax element" in the throttle body, and as the car heats up it heats up the wax and melts it, and that affects the iac i guess. anybody know anything about that?
eclipsed @ 3am
