Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 12-03-2006, 06:54 AM
Peter99 Peter99 is offline
Ball Joints?
I have a 01 EXP EB 110K miles. My driveway is on a hill and has a turn around that I back into. This requires me to make two sharp turns backing in and pulling out while on the hill. I am hearing a clunking noise some times while making this manuver. All other driving conditions are normal.
Pete
Old 12-03-2006, 08:12 AM
Scrapper Scrapper is offline
AF Premium User
Re: Ball Joints?
have you jacked it up to see if it is ball joint's?? i'm sure the lower one's are wore if you have never changed them..i just done a 2000 ford pick up bottom one's was wore bad..anyway you can go to auto zone and rent the press to press them in.when you take tool back they give all your money back incase you don't know that....good luck...
scrapper
Old 12-03-2006, 09:14 AM
carlos80 carlos80 is offline
Re: Ball Joints?
is it a 4x4? if it is there s a TSB on the front crossmember FORD try tightening the bolts for it if that doesn't work for recommends you put a compound between the crossmember and the chassis that will stop the popping(i believe its cold weld but not sure)
Old 12-05-2006, 04:16 PM
Re: Ball Joints?
Thanks will work on that
Old 12-08-2006, 06:32 AM
Re: Ball Joints?
Well, 500 bucks replaced lower ball joints and front end alignment and it still clunks while turning. I saw for myself that the left lower ball joint had exessive play. But it didn't fix the problem. After I left the shop and drove thru town any noise dissappears. I went into a parking lot a cut sharp figure 8's and the noise is gone. But!! when I engage the 4 wheel drive the noise returns. The parking lot was covered in snow so its binding on dry pavement. I am suspecting one of the front drive shafts and or it's joints.
Pete
Old 12-09-2006, 01:00 PM
bearcat329 bearcat329 is offline
Unhappy Re: Ball Joints?
Pete
sounds like a CV joint in either side of the front axles
hth
Rick< Ore
Old 12-09-2006, 02:30 PM
AF Premium User
Smile Re: Ball Joints?
hth
Rick< Ore
sure does cat....
Old 12-09-2006, 05:40 PM
Nope. Another big buck repair. Noise from the tranfer case. It hurts so good.
Pete
