rough starting
I have a 1999 Silverado 1500 LT with 47000 miles. I just bought it from an older guy who hasnt driven it much in three years since his stroke. OK, heres the problem... when starting (not every time) I have to crank it over for a few seconds and give it a little gas once started. It then idles rough for 5 seconds or so. I had the codes read with a cheap code reader and nothing was found. Any ideas????
Re: rough starting
I would do a fuel pressure test.
Measure: Cold fuel pressure (ignition on - engine off) Cold cranking fuel pressure Engine full warm pressure Pressure after engine off Pressure should hold after engine off so watch it for 5 minutes or so. Post back what you find. //2000CAYukon |
Re: rough starting
If yours is anything like my problem was, it runs fine once started but just getting it to start was a problem, especially after already being driven for the day. Initially I thought it was the basics; plugs, wires, possibly plugged fuel filter. As it turned out, after noticing similar posts, it definitely had the symptoms of the Fuel pressure regulator. I went to a local parts store and it was $70, and about a 15 minute procedure to replace it. And that appears to have done the trick, it fires right up first try everytime now, just like it used to. Mine is a 2000 Z71, 5.3. The regulator is located on the driver's side fuel rail right on top of the intake, it's even easy to get at. I would definitely give this a try, it worked on mine. Good Luck!
Re: rough starting
![]() ![]() 2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running. |
