Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 12-02-2006, 05:51 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
New SE-R + SE-R Spec V
I was just wondering if anyone has seen this. If you haven't, here is some info on the 07 SE-R and SE-RSpec v.
http://www.topspeed.com/cars/nissan-...v-ar16849.html
Old 12-03-2006, 03:13 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: New SE-R + SE-R Spec V
Sweet! A higher-revving, 200hp QR25.
Dunno about the looks though.....hmmm.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 12-03-2006, 05:30 PM
ProZach626's Avatar
yeah I hear ya. I don't know what they were talking about when they said "a sporty look". Just looks akward.
Old 12-03-2006, 11:33 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
looks like ill be renting a spec v from enterprise and stealin me a motor, if i bolted up my mods to the new motor id be making some actual power
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 12-04-2006, 07:48 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
o geez. this isnt good. now they are going to want to compare th spec-v to the rsx and that market as well. i have no idea how it would do. the new looks also dont scream "sporty" to me. what is the rev limiter stuck at for the qr motor before this one? im sayin if i can rev higher than it, id prob just laugh.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 12-04-2006, 10:37 AM
fugiot's Avatar
The 02-06 SE-R's redline was 6200rpm. Waaayyy too low for a "sport compact". Short gears + low redline =
Don't make me ANGRY
Old 12-04-2006, 01:39 PM
yeah but if they "totally redesigned" the top end then why couldnt they get the rev up to 7250 like technosquare can? it seems like if they improved the valvesprings and valves and rods like they said they did then it should have no problem revving to 7250, which would make the thing a fucking monster, higher revving cams and a 7200 redline would make that thing rape a rsx, there would be no comparing them
Old 12-04-2006, 08:33 PM
Chiquae07's Avatar
i could do that for about 600 bucks. that would be pretty equivilent to a spec-v in the 1/4 id say if i was in manual.
Old 12-04-2006, 10:09 PM
lol since i picked up a bike i havent even thought about making my car any faster, something about pulling off a wheelie from 60mph by rolling the throttle back in 5th gear just takes all the fun out of a sentra.....
Old 12-04-2006, 10:22 PM
Chiquae07's Avatar
i dont blame you. ive basically given up on the auto sentra. unless anytime soon i can find the same model one but manual, looks like its all over for the sentra anyway.
Old 12-13-2006, 01:13 PM
neogeon neogeon is offline
oh stop bitching about the redline, once you consider ratios it really doesnt make a damn bit of difference. Take this for instance, the integra type R and spec v (02 anyway) have almost identical shift points mph for mph, so in the end the redline doesnt make a shit bit of difference. Why is everyone such a RPM fanboy?
Old 12-13-2006, 02:21 PM
because my bike redlines at 12k and i shift out of first at 90mph, redline is HUUUUUGE in an engine, the fact that integras make 0 ft lbs of torque means their gears will shift around the same time the specs do because they are geared lower, so the extra 2k rpm they have to play with enables them to run a lower gear to compensate for the rediculous lack of torque that a shitonda motor makes, not to mention that with the heads and displacement that a spec has if you ran the redline up to 7200 you would make another 10whp just from increased crankshaft momentum alone, it would also make the shift point around 35mph instead of 25 like it is now, which enables greater acceleration time before your first shift lowering your 60ft times at the track, seriously dude, dont post about something you have no clue about, we dont like to hear yourself talk
Old 12-13-2006, 03:39 PM
fugiot's Avatar
Yeah, but the Integra has an ultra-high redline and much shorter gears than a Spec. So even with the major power disadvantage(yes, the Spec is more powerful), it manages to be much faster(15.4 vs 14.9). Why?
Seeing as how both cars weigh about the same, it's because the redline is a good 2000rpm higher in the ITR. This means Honda was able to mate it with much shorter gears resulting in more power getting to the ground, while maintaning a reasonable peak mph in each gear.
58mph@6200rpm in the Spec
vs
58mph@8400rpm in the ITR
You tell me redline doesn't matter...
Don't make me ANGRY
Old 12-14-2006, 08:10 PM
ProZach626's Avatar
Wow, I didn't know the type R was that fast. I have beaten one before by about half a car length probably around 100 mph. It was a damn good race, but maybe that guy just put a type R badge on his car. Hmmmmmm
Old 12-14-2006, 08:32 PM
fugiot's Avatar
Type-R's are no joke, but they are also extremely rare. More than likely, he just put a Type-R wing and badge on his GS-R.
Don't make me ANGRY
