Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 12-02-2006, 05:32 PM
95montez34 95montez34 is offline
a few questions on a 95
the first, is the security system stock?
second, i seem to be losing oil, no puddle, no smell, and the temp is fine, where is it all going?
the last is a bit more out there but im looking for a turbo for my 3.4L, if i were to find one what would i need to change so i wouldnt end up on the side of the road with a busted car?
the help is much appreciated
Old 12-04-2006, 10:36 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: a few questions on a 95
The security system, VATS, Passkey and Theftlock are stock.
How much oil at what frequency?
Can't help ya much on the turbo issue :sorry; But me personally, unless it was a DOHC 3.4, I wouldn't give it much thought.
Old 12-04-2006, 03:28 PM
over a couple weeks it loses about half a quart, nothing to terrible but it is a bit of a nuisance, sorry i wasnt specific, but that is the exact engine that i do have, the 3.4 DOHC, ill try to include a bit more info
Old 12-04-2006, 04:34 PM
wrightz28's Avatar
Well, some sonsumption is normal, but I find that a bit on the excessive side. No smoke at startup or heavy acceleration? If it's not leaking externally, it's either being burned, hence smoke, or getting poast the head gasket into the cooling system
I would certainly determine where the oil is venturing off to before doing anything out of the normal operating limits of the engine in sound condition.
Old 12-04-2006, 06:22 PM
alright ill take another look at it, by the way about that stock security system, i press the unlock button, it unlocks the door on the driver side only, which i assume is normal, but when i press the lock button, it locks the passenger side and the driver you can still open and the system will just go off, any suggestions? thanks for the help again
Old 12-05-2006, 11:30 AM
wrightz28's Avatar
Could just be a sticky actuator on the passanger door?
My wife's car we just bought only saw usage of the drivers door for the last 5 years so the all the other doors were pesky to unlock. A few shots of WD-40 cured the situation.
Old 12-06-2006, 12:03 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Most GM factory keyless entry systems are set up to only unlock the drivers door with one push of the button. A second push of the button within 3-5 seconds should unlock all doors if the system is working properly. The lock button should lock all doors with one push.
The oil consumption is harder to track. If it's not leaking on the outside of the engine and reaching the ground, it's an internal leak. But if it's internal, that kind of oil usage would cause blue smoke out the tailpipe. There is a oil pump drive o-ring that is a common oil leak issue on all GM 60-degree V-6's. It is located beneath the throttle body on the drivers side in the center of the block. It will usually run down the back of the engine and appear to be an oil pan gasket or rear main seal leak. It may only be leaking at driving speed/RPM and not at idle. This would cause the oil to be blown off and it may not hit the ground while parked. An inspection of the undercarriage would show the oil on the bottom of the car if this is the case.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-06-2006, 03:35 PM
thanks that solves the locking question i had, the oil i did spot a small mark on the driveway so im going to take a look at that, probably a gasket like you guys said, that problem can be figured as solved too, i understand this forum is mostly fixes and diagnoses, but im still wondering what to do for a turbo, is there any brand you know of and besides the turbo unit itself, what else will i need to add/replace. again i do have the 3.4 DOHC engine. thanks.
Old 12-06-2006, 09:37 PM
richtazz's Avatar
Putting a turo on the problematic, tempermental 3.4 DOHC is not a good idea. These motors have enough inherent problems, adding boost will just compound them.
Old 12-06-2006, 11:03 PM
ChevroletTough's Avatar
ChevroletTough ChevroletTough is offline
Send a message via AIM to ChevroletTough
i couldn't agree more!!! The 3.4 is powerful, but has so many potential problems.... Im a GM fan down to my bones, don't get me wrong, hell i have a a tattoo of a bowtie wrapped in barbed wire on my arm! I can show you if you don't believe me.
But the 3.4 is not my fav engine. Get a strong 3.8 3800 series engine. I prefer a 5.7 350
Ive owned my 1995 monte carlo z34 for about 5 months, and it ran great for 4 of those months, and then i got hit with a fuel regulator, head gaskets, vaccum line, prom chip update, cam shaft sensor, and 02 sensor. This is just too many problems for me.
1995 Monte Carlo Z34 DOHC
1989 Silverado 350cu TBI
Aaron
