Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-02-2006, 01:53 PM
darnsuprat darnsuprat is offline
Question about Overheating while stopped
I've read a lot of posts here about the venture overheating. I have an 02. While stopped at red lights or in the drive thru etc, the temp will rise to about 3/4 but will quickly come back down when driving.
Has anyone here experienced this? I changed the thermostat thinking it will solve the problem but that didn't do it. The coolant is still good and doesn't seem to be mixed with oil or anything like that.
Is this head gasket or intake gasket or what?
Old 12-02-2006, 02:53 PM
serial serial is offline
Re: Question about Overheating while stopped
I have the same problem. I've had the intake gasket replaced and it still does it.
It doesn't happen at every stop but likely a few times a week. I'm ignoring it for now.
Old 12-03-2006, 10:48 AM
Wish I knew what the problem is. I'm worried that in the summer, it'll just get worst. We're in Florida and it's December and the temp gauge is rising at stop lights........I'm worried what's going to happen in summer. We've been having warm temps here in Tampa for a few weeks now.
Did you have the intake gasket replaced by the dealer? Did the mechanic know why the temp is still creeping up even after the gasket change?
Old 12-03-2006, 11:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Might be just normal operation.
Dash gages are just tempt indicators.
We would need to know true tempt it is getting to.
A electric fan with AC off does not kick in until around 220 degrees.
Turn defrost or ac on and see if it holds around 195-200 degrees
The fan should run all of the time with AC on.
MT
Old 12-03-2006, 07:17 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
That's my theory too. Both of my Ventures have acted that way for years, even through intake gasket changes and numerous thermostat replacements. The coolant levels have remained constant with no other problems.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 12-04-2006, 11:05 PM
GregA's Avatar
GregA GregA is offline
I believe this is "Normal" too.
The issue I have with my Venture is that there are no "Temperature Readings" (number) and the gauge. So I decided to do some measurements and draw some numbers on a picture of my temperature gauge. Your results may vary. I have the results at the following link.
Temperature Gauge w/Numbers
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 12-05-2006, 07:50 AM
Great job GregA.
So, if your numbers/drawing is accurate, then that means the normal operating temperature is between 198 and 212, correct? When stopped, my temp climbs anywhere from 212 to just past the 226 mark. I check my coolant once a week to make sure there's no sign of a bhg.
Old 12-05-2006, 08:38 AM
MT-2500's Avatar
AF - Advisor
Take Care,
Dash tempt and dash oil gauges all depend on electrical sensors to tell them what to do.
For the dash tempt gauge. Here is the best thing to check it.
http://www.calright.com/_coreModules...FRieWAodkzhWpA
But the tempt sensor that works the electric fan on and off is a different tempt sensor for the PCM.
Both should be checked if any overheating problems.
The best way to hold the tempt down at a stop light or sitting still is with the defrost or AC on which should keep the fan running all or most of the time.
MT
MT
Old 12-06-2006, 01:03 AM
GregA's Avatar
Great job GregA.
Thanks for the input. I believe that should be about right, but on my van the gauge sits around the 184 mark. Since I bought it used, I kind of suspect that maybe it has a 180 degree thermostat in it.
Also, when my van is stopped (sitting in the driveway or in the drive-thru), it does pretty much the same thing as your van (200-to-226). I took the data from a couple of cycles and plotted it the following page. It shows that the fans turn ON at about 225 degrees F (just what the factory manual says 220-230).
Engine Cooling Cycle
Take Care,
Greg A.
Old 12-06-2006, 01:14 AM
GregA's Avatar
MT
I agree. I plan on verifying my numbers with a tool such as you mention, I just don't have one handy. I also agree that the best way to keep the temp down is to get the fans to come on, as you mentioned above.
I am not aware of a separate temperature sensor for the fans and the PCM, at least for my year van. According to the information I have, the sensor input goes to the PCM and then the PCM controls the fans. See link below (info is based on data from the factory manual).
Engine Cooling System
Take Care,
Greg A.
Old 12-06-2006, 10:23 AM
bleepster bleepster is offline
I have an '04 Venture. During the summer, my temp. gage is always pointing straight up - 212 degrees. While waiting in a drive thru - it may climb to about 226, and stay there.
once drive starts again, it goes back to 212 degrees.
now its colder out (michigan) - its about 205 degrees
the topic of this post is "over heating while stopped" - not being a smart butt, but you HAVENT over heated. Temp gauge has not gone into the red, no steam etc.
to me, there is NO problem. So try to not let it bother you.
(all my temps reference GREGA's gage he made)
Old 12-07-2006, 10:51 AM
GregA's Avatar
Just an UPDATE: I used an Infrared Thermometer from an auto shop and have VERIFIED the numbers I got for the temperatures on my van. It showed that the temperature readings were within a few degrees (F) when measured within about 1 inch of the sensor (around the thermostat housing).
Take Care,
Greg A.
Old 07-02-2007, 08:49 PM
kidfam kidfam is offline
I have been experiencing this issue lately with my 98 Olds Silhouette however, when I go under the hood I have found the drivers side fan it not running. Jingling the wires and connector seems to get the fan running and the temperature on the gauge goes from 3/4 back to a little over 1/4 scale
Old 07-02-2007, 09:14 PM
Please do not resurrect old threads. If you have something new to add, start a new one.Posting in closed or outdated threads
Closed Thread
