Old 12-02-2006, 11:24 AM
mcgirkz mcgirkz is offline
1992 lesabre batter going dead
hi all, i'm new here. glad to be a part of this fine group. a wealth of information here.
my problem; i have a leasbare that the battery is always going dead. after i charge the battery up with a trickle charger, i am good for about 36 hours before the battery is drained to the point where i need a boost. the car boosts fine but always goes dead after 36 hours???
i have replaced the alternator and battery in the last year. i had the car in for a draw test at a mechanic's shop and the only thing that was suggested was removing the fuse for the radio as it was the only significant draw they had found.
a bit of history; a few years ago i had the keys locked in the trunk. a couple of mechanics did something in my glove box to get power to the trunk release. i'm not sure if that has any reason for my problem?
Old 12-03-2006, 07:32 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1992 lesabre batter going dead
Welcome to AF.
What this significant draw/parasitic drain before the radio fuse was pulled? How many milliamps of current?
Look at the battery reserve capacity to determine abnormal draw. For example if reserve capacity is 120 then divide by 4 which equals 30 mA of current. Up to 50 mA may be acceptable but to drain a battery in 36 hours means it is a lot higher.
Timeslip 08/12/06
AF Community Guidelines
Old 12-03-2006, 10:01 PM
i shoulf have been more specific in my first post. i had the car still at the mechanics and had not pulled the fuse for the radio yet.
what i did was charge the battery up with the trickle charger overnight, i removed fuses 11 and 24 from under the drivers side dash. and let the car sit for approx 24 hours. the temp is also sub zero here. the car started today with the 2 fuses still left out. i am waiting tonight as well and i'll see how it starts tomorrow. if all is well, i'll look into replacing the radio.
Old 12-04-2006, 07:29 AM
imidazol97 imidazol97 is offline
AF -Advisor
Originally Posted by bnaylor
Welcome to AF.
If reserve is 120 then that means it would supply 25 amperes for 120 minutes before falling below the nominal minimum voltage level under load. So if a radio requires 30 mA to retain its settings that would be 25/0.030 which would be 833 hours. (The reserve capacity draw rating is probably not linear so I believe it would last even longer at a low draw compared to the high draw meant to approximate headlights and ignition usage for a car whose alternator has failed.)
In other words the keep memory alive draw of a radio and computer aren't draining the battery. It's more likely some other quirky draw. Example is a neighbor's Gran Prix which would draw down the battery occasionally overnight. Other times it wouldn't happen. He thought it was his alarm system (not factory). Turned out the shadetree mechanic another neighbor who has lots of experience with GM used cars replaced the starter. Fixed it.
First I'd look at the cables and even alternator cables for poor connections or corrosion. Does trickle charging charge battery to full charge or is the car driven long enough-30minutes or more- to fully recharge the battery?
Old 12-04-2006, 09:01 AM
BNaylor's Avatar
Reserve Capacity
Reserve capacity is the amount of time in minutes it takes a fully charged battery, being discharged at a constant rate of 25 amperes and a constant temperature of 27°C (80°F) to reach a terminal voltage of 10.5 volts . Refer to Battery Usage for the reserve capacity rating of the original equipment battery.
Cold Cranking Amperage
The cold cranking amperage is an indication of the ability of the battery to crank the engine at cold temperatures. The cold cranking amperage rating is the minimum amperage the battery must maintain for 30 seconds at -18°C (0°F) while maintaining at least 7.2 volts . Refer to Battery Usage for the cold cranking amperage rating for this vehicle.
Parasitic Drain
In automotive terms, a parasitic drain is an electrical load that draws current from the battery when the ignition is turned off. Some devices, such as the PCM and the radio memory are intended to draw a very small amount continuously. These draws are measured in milliamps (mA).
In normal use, parasitic drains aren't usually cause for concern, because the battery is replenished each time the vehicle is driven. But, in long-term parking situations, parasitic drains may discharge the battery enough to cause a no-start condition. New vehicles in dealer stock and airport long-term parking are two such situations.
An abnormal parasitic drain could be a glovebox or luggage compartment light that remains on but undetected. Or an electronic component may malfunction and cause a parasitic drain that is larger than normal specification.
Parasitic Drains and On-the-Lot Battery Discharge
Important: In most cases of discharged batteries in low-age, low-mileage vehicles, proper charging procedures with approved charging equipment is the only repair necessary.
Here are some rules of thumb that might help relate parasitic drains to how long a battery would last on a parked vehicle. The Reserve Capacity (RC) rating multiplied by 0.6 gives the approximate available ampere-hours (AH) from full charge to complete rundown. Somewhere between full charge and complete rundown, the battery will reach a point at which it can no longer start the engine, although it may still operate some of the electrical accessories.
Using up about 40% of the total available AH will usually take a fully-charged battery to a no-start condition at moderate temperatures of 25°C (77°F). Put another way, for a typical battery in a storage situation, depleting the available AH by 20 to 30 AH will result in a no-start condition.
Important: If the battery begins storage at 90% of full charge, reduce the available AH accordingly.
The recommendation for maximum parasitic drain is around 30 mA (0.030 amp). A typical drain today actually falls into the 7-12 mA range, even though some vehicles do approach the maximum. Multiply the drain (in amps) by the time (in hours) the battery sits without being recharged. The result is the amount of AH consumed by the parasitic drain. The actual drain may be small, but over time the battery grows steadily weaker.
Here's an example: a vehicle with a 30 mA drain and a fully-charged 70 RC battery will last 23 days. But if that battery is at only 65% of full charge (green dot barely visible), it is going to last only 15 days before causing a no-start.
Effects of Temperature on a Standing Battery
The parasitic drain will be fairly constant over a range of temperatures. The important temperature is that of the vehicle at the time a start is attempted. Colder temperature raises the threshold of a no-start by increasing the residual power needed. When the temperature falls to 0°C (32°F), the battery will be able to put out only about 85% of its normally available starting power, and the engine may need as much as 165% of the usual power to start.
The combined effect of these two factors is to reduce the number of days the battery can stand with a parasitic drain. At 0°C (32°F), the battery can stand only half as long as it could at 25°C (77°F). And at -19°C (0°F), the standing days are reduced to one-fourth.
Temperatures above the moderate climate of 25°C (77°F) increase the battery's internal self discharge. If the battery is in a locale where the temperature is averaging 32°C (90°F), an additional 5% to 10% of the available ampere-hours will be lost in a month due to self-discharge within the battery. At temperatures below the moderate range, self-discharge will be low enough to be negligible compared to the parasitic loss.
What the Policies and Procedures Manual Says About Parasitic Drains
Because determining how long a battery may last in a storage situation is not precise, the P & P manual provides a clear-cut policy, excerpted here.
"Discharged batteries can freeze at temperatures as high as 0°C (32°F), causing permanent damage. Other permanent damage may result from allowing batteries to stand discharged for extended periods."
"To alleviate this condition, the negative battery cable should be disconnected on vehicles which are not going to be in service within a 20 day period, beginning from the time the vehicle is shipped. If this is not possible, batteries should be recharged periodically, every 20-45 days, until the green eye is visible."
"Disconnected batteries will slowly discharge, especially with higher temperatures; therefore, even disconnected batteries should be checked every four months and recharged if necessary."
"Vehicles on display are subject to battery discharge due to drains from courtesy lights and other accessories. Provision to maintain battery state of charge for these vehicles will be necessary."
Consult your P & P manual for full details.
Tracking Down the Source of a Parasitic Load
If the battery in a vehicle becomes discharged in a shorter time than described earlier, the vehicle may have an out-of-specification parasitic load. Refer to Service Information (SI) for procedures for locating parasitic drains. Follow these steps:
1.Build the vehicle.
2.Select the Engine section.
3.Select the Engine Electrical sub-section.
4.Select Diagnostic Information and Procedures.
5.Select Battery Electrical Drain/Parasitic Load Test.
You will need the J 38758 Parasitic Draw Test Switch and a digital multimeter set to the 10A scale.
Important: Read the procedure and follow the steps exactly as described in SI. The following is a summary, not the complete procedure.
The test switch permits you to place an ammeter in series with the battery negative cable. Before performing the test, the engine must be run and all accessories must be operated as instructed. After shutting the ignition off, turn the test switch off. Now, all the current being used by the vehicle is shunted through the ammeter where it is measured. If the reading is out of specification, the procedure explains how to pinpoint the cause.
A Final Word About Battery Testing
Your dealership has an essential tool, the Midtronics Micro 410 Battery Tester, J 42000. Use it to quickly identify batteries that are serviceable and can be charged. Refer to Corporate Bulletin Number 02-06-03-006A for more information about this tool.
Timeslip 08/12/06
Old 12-06-2006, 01:18 PM
Whoaru99 Whoaru99 is offline
Do you have any non-factory electrical stuff installed? A trunk full of amplifiers, for example?
