Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 12-02-2006, 06:29 AM
jeffharley jeffharley is offline
Send a message via AIM to jeffharley
96 TC Front end
I have a 96 SC which my lovely daughter drove in and out of a ditch, then hit a curb. Now the front wheels are not centered in the wheel well. They are a lot closer to the rear of the fender well closer to the door. Is there any adjustment for this or is the frame or something bent? And if so is there any way to fix this?
Old 12-02-2006, 09:34 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 96 TC Front end
That is not good news. A common problem is the lower control arms will get bent/damaged from this type of accident. Also, check for any damage the subframe assembly and the struts. Best thing to do is perform a closer inspection to determine what suspension and steering components may have been damaged.
Timeslip 08/12/06
AF Community Guidelines
Old 12-02-2006, 11:01 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: 96 TC Front end
and alignment/chassis shop will have to check/inspect it
there could be and probably are several parts damaged, it may be very costly and not worth the cost if the car is anything except clean and low mileage
your best best may be to buy a cheap rear ended or non-running car of the same chassis design and swap the entire cradle suspension assembly from it
its no that bad you have to disconnect the power train harness and steering at the steering shaft knuckle and unbolt the top of the struts(easy) and disconnect the throttle and tranny cables, and exhaust pipe and lower the entire drivetrain and cradle suspension assembly and then swap your engine and trans onto the donor cradle suspension assembly and then put it back up under the car, four big bolts hold the cradle to the body,
good luck
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 12-04-2006, 09:26 AM
Re: 96 TC Front end
It goes in Thursday for inspection. I will post the results
