Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-02-2006, 03:55 AM
starygurl82 starygurl82 is offline
window relay
Hello, my driver's side window got stuck down. We were able to raise it back up. Now, the motor works so they think it's the relay but we weren't able to find the relay. Does anyone know where it is? And maybe what size it is? Thank you.
Old 12-02-2006, 05:30 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: window relay
Model year would help.
If it was a failed relay, none of the windows would work.
I would start looking at the switch, motor and associated wiring
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-02-2006, 04:42 PM
Re: window relay
sorry its a 99.. I have no clue about cars. we are in the military and overseas. I was at the auto skills center where they have mechanics. Where would we look exactly? We looked at the fuses in the side panel by the door and they were good. Thank you
Old 12-02-2006, 07:16 PM
e2helper e2helper is offline
Re: window relay
No relay there. It is a high current ignition switch and power window switches handle the motor current directly. So if when this happened it only affected one window then problem is either window switch, motor or wiring - no relay.
The fuse for windows is on a circuit breaker.
Old 12-06-2006, 10:53 PM
bugwubber bugwubber is offline
Re: window relay
Heh yeah- had the same thing. Was at a drive through and the window stuck down. In the middle of winter. Wasn't sure what caused it so I spent a lot of time with the door panel apart. Anyway, finally took the window switch apart and cleaned it out. Problem solved. My forehead hurt for awhile after though. If only.... ugh. Even though I cleaned it and put in dielectric grease, the problem did pop up again. So I wonder if just replacing the dang thing is the way to go?
