Old 12-02-2006, 02:03 AM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
Surging/Hesitation
Im having a problem with my truck where im having a bad idle (surging/missing) and what is almost like a flat spot/hesitation in the throttle at times. Sometimes it even just shuts off completly at a stop. I have replaced a lot of the sensors in the past except for the knock, ECT, CKP. The EGR valve, and EGR solenoid has been replaced along with fuel injectors, and fuel filter. Could this be a pickup coil problem, or an igniton coil? I dont think its a fuel pump problem, this has been doing this for a long time now, and is very random.
Thanks
89 Chevy K1500, Extended Cab, Long Bed, 5.7L, 700r4 tranny, 10 bolt rear
Things Done- Flowtech Headers, Heartthrob Deep Tone Dual Exhaust, Airaid TBI Spacer, K&N Intake, 3" Performance Accessories Body Lift, 285 75 R16 Pro Comp A/T Tires, 16" Americain Racing Outlaw 2 Rims, Fabricated Bumper Replacement.
Old 12-02-2006, 11:15 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Surging/Hesitation
have you removed and cleaned the IAC in the tbi unit yet, have the TPS tested or find the instructions online or from a technician on how to test it with a multimeter
good luck
make sure the fuel pressure is normal and that the O2 sensor is ok, as they dont last forever either
the flat spot in the throttle sounds like fuel delivery or TPS issue, the TPs is one of the sensors involved with fuel delivery, so...
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 12-02-2006, 11:53 AM
2000CAYukon 2000CAYukon is offline
heavyredchevy,
I recently fixed a miss problem on my 90 GMC K1500. I also have a surging idle that I have not fixed yet but it is not as bad as before I fixed the miss.
In my case, the vents on the base of the dist were clogged and the terminals where the pickup coil connects to the ignition module were corroded causing a bad signal from the pickup coil.
I cleaned the vents, sanded the pickup coil terminals on the ignition module and coated them with dielectric grease. My low end miss was finally gone. Note that the ECM needs to relearn the fuel trims and it may take a week or so to relearn.
The pickup coil and magnet on the pole create an ac (alternating current) signal. This signal is converted to a dc signal which is used to fire the coil. It is also used by the ECM to fire the injectors.
If the pickup coil is weak or if there is a bad connection to the ignition module, a miss can occur.
In my case, when I disconnected the EST connector and watched the timing, it would jump around. This was caused by the bad connection at the ignition module.
//2000CAYukon
Old 12-02-2006, 04:36 PM
The IAC is new and set to specs, The TPS is new and also set to specs. I had the TBI off and cleaned all out. I replaced the injectors because they were dripping. Like i said i dont think its the fuel pump, i checked the pressure before and it was within specs. The fuel filter and line are new. The old on was falling apart. This is why i think it has something to do with the ignition. I really think its my pickup coil or something to that effect. I will check the things you said 2000CAYukon. Its below 0 outside right now and i dont have a garage to work in so ill have to wait untill i can bring it into the shop at school. Wyotech has a great program. They teach mostly theory so i need to get some experience for myself.
Old 12-04-2006, 06:48 PM
Today I was at a red light and the thing just cut out on me completly. It took a few minutes of cranking to get it started again. This is starting to become a real problem for me. Could this be the pickup or ignition coil? How can i test for problems.
Old 12-04-2006, 07:02 PM
Tall Tall is offline
Its a good chance it the pick up coil. Sounds like a problem a friend of mine had. Is it missing through out the RPM ranger?
Well; take the cap off; and look at the coil. Is it flakey? or Green looking? If so you should replace it.
Also test to see if the distributor shaft is wobly by turning the rotor and see if it wobbles at all.
Old 12-04-2006, 08:03 PM
On my 90, I could not see the pickup coil by taking off the cap. It has an RFI shield over it. In order to replace it, you need to pull the shaft out.
In my case, the plastic housing around the pickup coil had cracked and it looked very rusty.
If you have any play in the upper bushing, you will be better off replacing the dist since it will come with a new pickup coil, shaft and ignition module.
//2000CAYukon
