Old 12-02-2006, 12:29 AM
iwanafixmycar iwanafixmycar is offline
Exclamation 97 accord overheating, thermos seems ok
my 97 accord is not cycling the coolant, seems thermostat is opening as the upper rad hose is warm-hot, except the bottom hose is cool to touch, car runs ok for a while but overheats after about 10-15 mins of driving, rad cap was busted when i removed i was pretty much in pieces i am wondering is anything might have fallen and got the rad plugged/clogged? help
Old 12-03-2006, 01:06 PM
somick's Avatar
somick somick is offline
Re: 97 accord overheating, thermos seems ok
When the thermostat opens, the bottom hose suppose to get hot too! That means the circulation started. The temperature of the lower hose should be just slitely (few degrees) lower. From what you described I can tell that you need a new thermostat.
A pretty easy job.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 12-04-2006, 01:29 PM
mpumas mpumas is offline
I would start by replacing the thermostat. If that doesn't solve the problem you may have a plugged radiator and need to reverse flush it. Best way to do that is after it is removed from the car. The next fix maybe a water pump.
Old 12-05-2006, 11:36 PM
yep fellas, twas a case o bad thermostat, manual i read only mention if top hose gets hot then thermos ok. thank you all for your willing help. car running w out problems. thank you/bless you all.
Old 12-11-2006, 01:14 PM
gelcol gelcol is offline
Hi! is this a f22 engine 4 banger?
