Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-01-2006, 08:50 PM
sa_towns_gift sa_towns_gift is offline
Send a message via AIM to sa_towns_gift Send a message via Yahoo to sa_towns_gift
Got my LS in July
I got a 2005 silver Lincoln LS V6 with 21000miles. Black leather interior. So far I like it. I have a few questions that the forum maybe can help me with.
Can it fit 22in rims?
Can it handle 15in subs in the trunk?
What kind of after-market body kit can be bought and where?
Is it possible to get extra headrest to get name embroider or customized?
Are there any car clubs just for show?
What can be used to keeps what is under the hood looking clean?
thanks remember i am new.
Old 12-02-2006, 08:55 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Got my LS in July
Welcome to the forum. There are others on here that may be able to address the wheels, body kit, and show clubs.
What people usually fail to understand when they put larger wheels and tires on a car is that the brakes often times need to be upgraded as well to handle the extra rotating mass of the larger wheels and tires. The LS has good brakes for a stock wheel and tire combination, but braking performance may decrease significantly if you go with such a large wheel and tire package but don't upgrade the brakes. THE SAFETY OF YOU, YOUR PASSENGERS, AND OTHERS ON THE ROAD IS FAR MORE IMPORTANT THAN THE APPEARANCE OF THE CAR!
As for subs in the trunk, that will depend on what volume of box they need for the configuration. As you are probably aware, different subs require different sized optimal enclosures. Likewise, if you go with a ported enclosure, it will typically need more volume than a sealed enclosure. If you go with an isobaric enclosure, you may be able reduce the box dimensions as well. Keep in mind though that the battery junction box, battery, and spare tire is under the lower trunk liner. If you ever need to replace the battery or access the fuses, you'll need to be able to get the sub box out or relocate the battery and fuse panel.
I picked up a spare set of headrest off of eBay for my LS for a decent price. I'm not sure how often headrests are posted, but you should check eBay and local salvage yards.
-Rod
Old 12-02-2006, 05:26 PM
2005LSdude 2005LSdude is offline
showrod, I hope that rotating mass doesnt apply to me ?, I just put 17'' wheels on today, did have 16'' both sets where OEM wheels.
Old 12-02-2006, 06:37 PM
shorod's Avatar
SHO No Mo
You're probably fine, my 2004 LS V8 has 17" wheels (factory) and my wife's 2002 V6 has 16" factory wheels. Both have the same stock brake setup.
-Rod
