Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
View Poll Results: Did this help you find your problem?
Yes quickly 0 0%
Helped me know where to look at least. 0 0%
Not at all still lost 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 12-01-2006, 07:15 PM
Marknroll2000 Marknroll2000 is offline
Thumbs down NO DASH or INSTRUMENT LIGHTS 96 Sentra GXE
Before anyone tells me to read past posts I have and I've done all those with no luck. But just to run it down because what I say may help someone else that needs to have all the steps in one post!!!
1) First thing I know the interior lights are connected to the park light circuit which has a fuse under the hood on the right side, 15 amp. That is good in mine.
2) The dimmer switch is the primary connection between that fuse and the interior lights. It has 3 wires. I have tested the ground (black) with a continuity tester and it is good. I also have 12v on both the other wires.
3) I've taken the instrument cluster loose from the dash and pulled each bulb and tested them, all good. That is as far as I Know from there I'm lost.
Oh and I also have tried 2 -$50
dimmer switches !!!!!!!!!!!!!
any other ideas ????
Old 12-01-2006, 07:23 PM
Re: NO DASH or INSTRUMENT LIGHTS 96 Sentra GXE
" It is better to keep silent and let people think you are a fool, than to open your mouth and PROVE it!!"
Old 12-05-2006, 05:42 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
havent had that problems. i cants help you out, as im not that good with electrical wireing things. but i think this thread was a waste of a poll, if it did solve the problem we would post about it.
not tryin to come on soundin mean or nothing if i do, as i know i do sometimes and im not tryin to. im also confused by what you are also askin. please type it in english. thanks.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
