Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-01-2006, 07:15 PM
miguel2112 miguel2112 is offline
99 aurora rough idle
In the last 2 days my car is idling rough. This happens only when the engine is warm in gear at a stop. Also the heat must be on. Turn the heat control off and the idle smooths out, turn the heat on, rough idle. Seems to happen about the same time the a/c compressor kicks on. Rpm,s fluctuate between 500-700, battery voltage fluctuates with the low rpms 13.9 to 15 volts. Otherwise the car runs great down the road. ???????? any thoughts
Old 12-01-2006, 07:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 99 aurora rough idle
Try cleaning the throttle body and remove the IAC and clean that up and the passages, any CEL or codes?
Old 12-01-2006, 07:34 PM
No CEL, I'll have to get my scanner neighbor to check for codes. In the meantime I'll clean TB and IAC, I use B-12 for that, sound OK?
