1995 caravan - heat coming out cold
The air coming out of the vents is cold when I have the heat on. What should I check. I do have a new thermostat.
Re: 1995 caravan - heat coming out cold
Make sure the blend door is opening. Feel the heater hoses going to the heater core to see if they are both about the same temperature. If one is significantly hotter than the other, the heater core is clogged or restricted. How old is the waterpump? Waterpumps wear out, reducing the flow of coolant through the heater core.
If you can get to them watch the actuator and door. Here's what they look like: http://www.autozone.com/servlet/UiBr...3d8010c971.jsp Figures 4 & 5.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
