Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-01-2006, 04:30 PM
jdonojr jdonojr is offline
grease fittings
how many grease fittings on Bonneville 99 SSEI?
Old 12-02-2006, 08:45 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: grease fittings
Most factory suspension pieces are non-greasable. If anything has been changed before, then there would be a maximum of 4, 1 on each lower ball joint, and 1 on each outer tie rod end.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-02-2006, 09:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: grease fittings
Best way to find out is to jack it up and craw under there and count them.
And remember if some parts have been replace they may have fittings or may not so you just have to look to see what it has.
MT
MT
Old 12-02-2006, 07:22 PM
ecartman ecartman is offline
Re: grease fittings
All Bonnevilles from 87-99 have 8 grease fittings (Front + Rear balljoints, Front + Rear outer tie rod ends). The rear ones are easly visible when under the car. The ones one the front balljoints stick out of the sides not the bottom.
Old 12-03-2006, 08:38 AM
richtazz's Avatar
Re: grease fittings
Not from the factory they don't. GM went to mostly sealed chassis components in the mid 90's.
Old 12-09-2006, 01:28 AM
BBToast BBToast is offline
Re: grease fittings
I have them as described in earlier post front and back on my '97. No replacement work done on my vehicle, (at least on the suspension).
Old 12-31-2006, 01:36 AM
niemo810 niemo810 is offline
Send a message via AIM to niemo810
Re: grease fittings
my olds 88 (same h-platform as the bonnies) has 8 fittings from the factory.
