Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-01-2006, 02:52 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Question Coil on plug setup
Hi,
apparently the last step in my complete setup is a coil on plug system and new aftermarket fuel filter kit.
I was wondering what exactly are the benefits of a Coil on Plug setup...
I have a slight understand of what it is and does, but I would appreciate a full understanding.
Thanks,
Ben
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 12-01-2006, 05:10 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Coil on plug setup
It just puts an individual coil on each plug so that you don't lose any sparking power like a normal coil setup. It will also benefit to go with an msd ho box as well if you do the coil on plugs. This is something I will be doing in the near future if I don't do it while my motor is apart now.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 12-03-2006, 02:24 AM
--- --- is offline
If your turning 10,000 rpm and running 45 +psi it would be a good idea, but, only if you set it up for sequetial fire instead of wastefire. This allows you to double your dwell so your coils have a suffiecient time to recharge between firings. Of course, going to a CD ignition would accomplish the same end result in most cases and is somewhat cheaper, with the added purks of features most boxes have (studder, theft deterent, ignition retard).
I drive a slow car.
