Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-01-2006, 11:09 AM
Reg Saretsky Reg Saretsky is offline
Send a message via AIM to Reg Saretsky
"Code reader- who sells a good one?
guys& gals
who sells a good code reader for a 1999 Malibu- reasonable price, accurate, internet shipped would be great--
Any advise?
thanks
Reg
Old 12-01-2006, 11:15 AM
alphalanos alphalanos is offline
Re: "Code reader- who sells a good one?
Actron makes pretty good ones. I got one for about $80 at Autozone but im sure you can find it online. Your car should be OBD 2.
96 EJ6. Future home of boosted B18C1.
Old 12-10-2006, 09:09 PM
RT87 RT87 is offline
Harbor freight has two or three models that run from $40-60. If you are only going to read codes or reset them that should be all that you need. Your local auto parts store will most likely read codes for you for free, but some stores will not reset codes.
In my experience, there are two codes that come up frequently, one is for a loose gas cap, and the other is for insufficient EGR. Always check that the gas cap is on tightly as a start, and if that is not it, the code reader can pinpoint the system.
If you happen to get a code for insufficient EGR, the problem is more than likely a clogged passage between the EGR valve and the throttle body, rather than an expensive EGR valve. Hope this helps
Old 12-20-2006, 06:23 PM
bcopeland bcopeland is offline
What code would that be for the loose gas cap?
Old 12-21-2006, 03:59 PM
It has been awhile since I have had one, I believe it is P0442
Old 01-30-2007, 12:51 PM
ottawamalibu ottawamalibu is offline
We've attached my piece of crap Malibu to the code reader and all it does is flashes......(car isn't turning over.....wants to and tries to...but doesn't)
HELP
