Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 11-30-2006, 11:18 PM
djgraphics1223 djgraphics1223 is offline
1993 Dodge Spirit ES Trans Problems
ok i am having problems with my trans, first when i put it in drive it doesn't move until i give it some gas, second when i put it in reverse it doesn't got until it wants to or when i move the shifter around if im lucky. third when i drive i doesn't shift from second to third. i have no idea whats going on with the trans. if i could get any help that would be great. i really need to know what to do and also need to know what the problem is.
Old 12-01-2006, 11:20 AM
KManiac's Avatar
KManiac KManiac is offline
Re: 1993 Dodge Spirit ES Trans Problems
What you have there is a Chrysler 3-speed with lock-up. This is a much simpler transmission than the computer-controlled, Ultradrive, 4-speed automatic. These little 3-speeds are a modern, miniturized version of the old Torqueflite automatics used in RWD Mopars of the 60's and 70's.
First of all, the delayed engagement in any gear indicates either low fluid level, a clogged filter or both. Proper fluid level is a must. To check for proper fuild level, the car must be idling in Park and fully warmed up. The fluid and filter should be changed every 30,000 miles and you must use only ATF+3 or ATF+4 fluid. Now a few questions. Have you checked the fluid level? When was the last time you serviced the transmission (fluid/filter change & band adjustment)? How many miles on your car? What engine size do you have? Is it Turbo or not?
The erratic engagement of reverse and the lack of upshift into high range indicates a faulty front clutch pack. Malfunction of the front clutch can be caused by low fluid level, clogged filter or worn out clutch discs. Driving your car for a prolonged period of time with low fluid will wear your clutches out real quick.
If you haven't done so already, change the fluid and filter in the transmission. While you are there, adjust the bands, too. The low/reverse band adjuster is inside the case, so this must be done with the pan off. The kickdown band adjuster is on the outside of the case. There are only two bands. Refill with new fluid and road test. If this doesn't do the trick, you will most likely need a transmission rebuild.
I had the 3-speed automatic in my Dodge Shadow rebuilt four years ago. It cost me around $1,900 and was done by an independent transmission shop in my area. You can read about my transmission experiences if you search this forum.
Let us know what you do and what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
