Old 11-30-2006, 03:40 PM
mobileky mobileky is offline
99 3.5 radiator removal
yea i have a slow leak in my radiator and im definatally not going to put stop leak in it,, i was wondering were how do you take it out? and if the radiator shop could service it or would i have to get a whole new one
Old 12-01-2006, 09:58 AM
busboy4 busboy4 is offline
Re: 99 3.5 radiator removal
Hi
Just a brief observation: rockauto.com has new for $200-$250. Not sure if it is considered serviceable or not. I'll get back to you on removal.
Old 12-01-2006, 12:09 PM
Ok
radiator removal
-Drain coolant. Radiator drain valve lower left side. Block drain plug is accessible by taking off right wheel. It is at the 2 o'clock position of the flywheel.
-Remove engine mount strut - on top left between engine and front frame above radiator
-Remove engine mount strut bracket from upper radiator support-4 vertical bolts
-disconnect cooling fan wiring harness from engine harness
-disconnect outlet hose from radiator
-disconnect inlet hose from radiator
-remove cooling fan shroud, motors and fans from radiator - looks like 1 bolt ea. left and right upper, 1 at top center, and 2 at bottom center and the whole shebang should lift out
-disconnect transmission oil cooler lines from radiator
-remove the radiator mounting bracket
-remove radiator mounting brackets - seems redundant but that is what it says. Looks like two bolts, one ea. side at upper corner.
-remove radiator
-remove radiator mounts - on bottom at each end
Put it all back
Good luck
