Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 11-30-2006, 01:53 PM
dgm1 dgm1 is offline
01 GXE window & locks
Last week Dvr side pwr lock stopped working. All others work. Next day pwr windows (ALL) went dead (fortunately in UP position). Is this a fuse or short? How do I fix it? It sure makes it hard to go thru drive-thrus! Any help...thanks!!
Old 12-04-2006, 10:49 AM
Mr Berns Mr Berns is offline
Re: 01 GXE window & locks
I did some similar work on a Altima this past weekend with a similar situation.
1. Check to see if you can hear the relays clicking when you use the driver side main control - if you hear them then probably that control is bad.
2. Open up the control area of the driver side (windows) and unplus the yellow connector and try step 1 again. If you hear the relays clicking then that box (circuit inside) is probably bad. Have it replaced.
Old 12-04-2006, 10:58 AM
Thanks for your help. I hear no clicking at all. It is just dead. Since ALL windows are same way, could it be a fuse or master switch?
Old 12-04-2006, 11:34 AM
I did not hear any clicking until i played with the plugs attached to the control on the drivers side. There are 3 plugs going in ... play with the sequence of plugging them in and trying ... i doubt all your relays burnt out at one time or that all the motors burnt out.
I would see that way. I had a hard time finding any king of breaker or fuse linked to the locka dn windows other then that circuit board which is in the control on the driver's sid (in the plastic casing under the up/down buttons).
Old 06-16-2008, 06:48 PM
catkoot catkoot is offline
I have same issue and I hear the click u talking about ! So what is next?
